can't get 22mm o2 sensor bolt off ... i think rusted
any ideas? i've got the 3 piece set from autozone that has the deep socket and the piece for the 1/2" and the 3/8" ... with my 94 civ ex .. the deep socket won't fit because the wrench is blocked by my fan ... so i used the 3/8" seems to not grip and go right around it ... thought it was turning but i guess it wasn't i let my engine warm for about 2 mins reved it a bit ... sprayed wd40 on it still nothing tried using the 1/2" one seemed like there was more resistance but still not turning ... my friend said to try some liquid wrench ... I've TRIED searching but search hasn't been working for almost 24 hours now .. any suggestions? thanx guys
Modified by ibe2fly at 9:20 PM 10/30/2005
Re: can't get 22mm o2 sensor bolt off ... i think rusted (Kamin)
You need penitrating oil and maybe heat if the oil does not work! Are you using a O2 sensor socket?
Re: can't get 22mm o2 sensor bolt off ... i think rusted (Blitzed)
You can get the penitrating oil at a automotive store, NAPS, Kragens, Autozone. And so on.
It is just a deep socket with a groove cut up like 3/4 of the way up the side bro.
ya i got a deep one from napa for like 27 it didnt fit cuz the fan .. so i took back n got the 3pc one from a-zone for 15 + tax
Re: can't get 22mm o2 sensor bolt off ... i think rusted (ibe2fly)
Take your fan off bro, it is always good to use the socket with penitrating oil, use the oil spray it like alot saturate it and tap it lightly then the next day break it free.
i was thinkinh about that ... didnt look it up in my haynes ... how big of a job is it to take it out?
hey anyone have a post in their recent or saved topics about a diy on the fan removal so i can try and remove my o2 sensor tomorrow morning? i've got the haynes book but i love to compare and contrast my honda tech fellows' DIYs ... i'd search but search is STILL unavailable :-\ ... maybe they need me in their IT dept O:-) ... hehe well anyway much appreciated if anyone would help me out .. thanx
Re: (civic_driver)
ok i woke up early to try and get this done cuz i wanted to head out to danbury,ct today... so i think i've stripped the bolt ... so not cool ... it's so damn tight i've sprayed tons of wd40 ... i can't make it to the hardware store to get any pb blaster ... i don't think that'll even work now ... there's so little resistance ... anyway im severly screwed ... is there any other way to get the o2 sensor off? i'm scared to cut the wires cuz even then if i can't get the bolt off i won't be able to drive my car cuz there'll be no o2 sensor AT ALL even though mine's causing a CEL 41 code ... (o2 sensor heater) ... any suggestions from a desperate dutchess county civic owner ? thanx
hey looking at my new o2 sensor i see the whole piece is connected ... has anyone removed the o2 sensor by using vicegrips around the part of the o2 sensor that's sticking out ? i'd have to find someway to make it have a solid grip but that's an idea ... any auggestions guys?
Modified by ibe2fly at 10:32 AM 10/30/2005
ok well imma go try the vice grips idea :-\
Modified by ibe2fly at 11:32 AM 10/30/2005
Re: (ibe2fly)
you can get PB blaster (penetrating lube) at any Wal Mart... if that helps...
get your car HOT not just idling for 2 min, that also will help. And when you re-install it use some anti-seize (also available at Wal Mart, etc...) so it doesn't rust in place again.
Re: (Leeroy)
ok i just got back sprayed alotta pb blaster on it ... gonna wait about 5 mins then gonna warm up engine and try to get off ...
ok car's on gonna let run for about 10 mins
Modified by ibe2fly at 12:33 PM 10/30/2005
Re: (Ej1_coupe)
def stripped ... any ideas? should i try n break off the o2 sensor and tap bolt out the rest of the o2 ? it's gettin late and it's a sunday stores gonna be closing soon :-\
one way would be to weld a bolt on top of the o2 sensor and take it out that way but that's if you have a welder... otherwise, you can try and beat a smaller size socket (maybe 21mm or even an SAE socket) on top of the o2 sensor one and take it out that way...
i would cut the sensor with a saw saw so it doesn't get in the way since you'll be replacing it anyway
good luck!
good luck!
Re: (civic_driver)
ok ill try that ... gonna cut off the sensor and try to shove a 21mm closed wrench on there
just got off the phone with a dude from work he said try a pipe wrench ... gonna goto the hardware store AGAIN and get one of those...
what a day...
Modified by ibe2fly at 9:18 PM 10/30/2005
what a day...
