vtech problems
Re: vtech problems (jeys_si)
vtec, anyways , you have to be more specific than that, what motor ,what ecu, hell what car, did you just do a swap ? vtec will engage if several factors exist, oil press. , temp, throttle position, rpm, . give us some more info on the car....
first what kind of engine do you have?? and how do you know vtec isn't kicking in??
https://honda-tech.com/zerothread?id=1412978
u don't really feel a "kick" when vtec hits.. its like a smooth transition
Re: (BrokeAssPinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">dial 9-1-1</TD></TR></TABLE>
remember to tell them some is trying to jack you <U>vtec</U>...then tellem you need help soon or its gonna die...
j/k, try to clean out your vtec solenoid (3 screws, and 2 plugs, easy DIY!) Once off wipe everything down and clean out the little mesh filter. I switched mine with a newer, cleaner soleniod and it works alot better. Kicks in just alittle it harder, hence I only have an EJ8. But I can sell you mine for cheap, dealer goes for $200+.
Re: (jeys_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">Do you have a cel ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si »</TD></TR><TR><TD CLASS="quote">check the oil? </TD></TR></TABLE>
The oil needs to be at a certain level for vtec to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear »</TD></TR><TR><TD CLASS="quote">vtec will engage if several factors exist, oil press. , temp, throttle position, rpm, .</TD></TR></TABLE>
Does it not kick in at all, or is it kind of in and out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc »</TD></TR><TR><TD CLASS="quote">u don't really feel a "kick" when vtec hits.. its like a smooth transition</TD></TR></TABLE>
He should feel a difference when vtec hits. I certainly do, but many times d-series don't "kick" as hard.
-Shane
-Shane
Its because you dont have Vtech Nitro :
http://www.vtechkids.com/produ...d=291
Your car's fuzzy logic computer kicks in vtec based on rpm and gear. It could be electrical or mechanical, you should go thru the factory diagnostic in the helms.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeys_si »</TD></TR><TR><TD CLASS="quote">vtech is not kicking in. What could be the prob?</TD></TR></TABLE>
b16mike
05-13-2005 09:51 PM
