brake problems with my eg si!
I recently put new brakes and rotors on my eg si. In the past the pedal felt low, so I installed new brakes and rotors and its doing the samething. I bled the brakes with my friend in the order you are suppose to but my pedal is still low.
could this be my master cylinder going bad? And also I can hear the rotors against the brakes pads when i am coming to a stop.
i bled the brakes like 5 times already but still the same thing. i just serch around and i think it might be the master cylinder. as for the noise i hear from the brakes will driving, i can not figure it out. if i lift my car, the wheels spin freely with no noise. could it be my hub bearings? i shaked both wheels and they are nice and stiff.
Re: (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">I can hear my brakes really loud too but I just assumed it was because my interior is stripped out</TD></TR></TABLE>
i have full interior, we might have the same problem
Re: brake problems with my eg si! (jay-d-em)
master cylinder seals are prolly bad, it sounds like you have no pressure. It wouldnt suprise me if your master cylinder is inoperative.
Re: brake problems with my eg si! (Altizzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altizzy »</TD></TR><TR><TD CLASS="quote">master cylinder seals are prolly bad, it sounds like you have no pressure. It wouldnt suprise me if your master cylinder is inoperative.</TD></TR></TABLE>
i am also thinking that is the reason i hear the brakes rub on the rotors.
i had the rubbing noise once. i accidentally bent the metal cover on the inside of the rotor while renchin on my caliper. it was bent in and rubbed while i was driving... ? just a thought
Re: (minus)
You have new pads and rotors, that rubbing sound is pretty normal with new brakes. I had it when I got mine and it has since gone away.
The pedal problem could be a number of things. Bleed your brakes a couple more times and make sure that the brake fluid NEVER gets anywhere close to being empty. If that doesn't do anything, I'd say it's the master cylinder.
Re: brake problems with my eg si! (spoonracer84eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">One of my calipers is locked up...</TD></TR></TABLE>
what kinda car ?
what kinda car ?
Tx92AccordExD
05-15-2003 11:39 AM
