Throttle body noise
Throttle body noise
i have a 97 coupe all stock, the throttle body makes this whistling noise. i took of the intake to see if that was causing it but it still does. it only makes noise if i floor it or if i hold the gas pedal at certain levels. thanks in advance for all your help.
Re: Throttle body noise (rsf-g)
sometimes the throttle plate is a little out of position from the factory. this will cause a little whistling noise at a certain rpm. i wouldn't worry about it unless it is really annoying to you.
crxtreme27
08-31-2002 11:49 AM
