M11-1.25 bolt? where can i find them?
Go Tigers!
Anyone know where I can find one of these bastards. Honda decided to be awesome and use the most bass ackwards dimensions for their engines
And yes, i am POSITIVE that it's M11-1.25
Re: M11-1.25 bolt? where can i find them? (Bense)
At the risk of sounding stupid...
did you try
http://www.hondaautomotiveparts.com
I also once found a few nuts and bolts places online too...
such as:
http://www.boltdepot.com/Catal..._id=5
did you try
such as:
Go Tigers!
The OEM bolt will not work. It is custom and is too long. I have already tried to modify it and ruined my bolt.
The bolt has a thread section of M11-1.25, then it has a unthreaded section that is 0.389" which is too small for to thread with a 7/16-20 die. The bolt then is "reduced" to a M10-1.25 Thread.
A M10-1.25 die will not fit over the unthreaded section either. IT HAS to be a M11-1.25 bolt.
The bolt is here #27 It's for the timing belt tensioner on my F20B.
Re: (Bense)
Thats really bloody weird. I suggest if you have a bolt shack type place try asking them. Or atleast for a die of that size. If you could fine that grab any M11 and go to work. You already tried cutting the top and tapping it to your 10 x 1.25?
Go Tigers!
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Thats really bloody weird. I suggest if you have a bolt shack type place try asking them. Or atleast for a die of that size. If you could fine that grab any M11 and go to work. You already tried cutting the top and tapping it to your 10 x 1.25? </TD></TR></TABLE>
I even have a thread pitch and bolt gauge, It's definitely M11-1.25
I have no clue why honda is doing this. What I am hoping is that MAYBE i can find a m12-1.25 die and beginning to thread it and modify the other end of this bastard.
Darth ModerVader
Re: (Bense)
http://mdmetric.com
According to one individual on a forum I came across:
maryland metrics has anything you can dream up.
I needed a 11x1.25 and 9x1 nuts, and they just said "what material and finish?"
Go Tigers!
+SCREW+ this, i'm just gonna go 7/16-20 It's basically the same thing.
I'm gonna have to make a stud though and use JB weld as loctite in there.
7/16 = 0.4375"
11mm = 0.43307"
The emperial 20 thread pitch is very similiar to the 1.25 pitch.
7/16 = 0.4375"
11mm = 0.43307"
I am pretty sure that you can find it at lowe's or home depot. It's not going to be the nice bolt like an OEM honda one, but they carry a limited quantity of metric stuff. I just bought some bolts there the other weekend for my front end. Not sure what their largest sizing was, but I'm pretty sure I bought M10-1.25 and that wasnt the largest.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">Anyone know where I can find one of these bastards. Honda decided to be awesome and use the most bass ackwards dimensions for their engines
And yes, i am POSITIVE that it's M11-1.25</TD></TR></TABLE>
Bense,
If these guys dont have it no one will.
http://www.hillcofasteners.com/
Bense,
Go Tigers!
Re: M11-1.25 bolt? where can i find them? (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">
Bense,
http://www.hillcofasteners.com/</TD></TR></TABLE>
1.04" isn't long enough. It needs to be 2"
Mr. Bense,
We don't stock anything 11Mx1.25. However, we distribute for ARP and they show a Toyota flywheel bolt 11Mx1.25 with an under the head length of 1.04". ARP flywheel bolts are low profile 12-point and the wrench size is larger than a normal bolt. Please let me know if you need any further information. Thank you for contacting Hillco Fastener Warehouse.
Billie
7522 Park Avenue
Garden Grove, CA 92841
714 657-7442 FAX: 714 657-7455
Bense,
Mr. Bense,
Billie
7522 Park Avenue
Well i tried...they have had every bolt i have ever needed. If nothing else i provided what i think is a good resource. Hope it helps you or someone else in need of a bolt in the future.
The f20b is jdm and edm only right? Is there not a way that a local dealership can't order that bolt for you from over there and you get it that way?
Go Tigers!
Re: M11-1.25 bolt? where can i find them? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Did you try the resource I posted above?</TD></TR></TABLE>
Yes I looked there, it just seemed to be like a trafficjam of information. I just didn't feel like navigating.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">The f20b is jdm and edm only right? Is there not a way that a local dealership can't order that bolt for you from over there and you get it that way?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">The OEM bolt will not work. It is custom and is too long. I have already tried to modify it and ruined my bolt.</TD></TR></TABLE>
It's not even a JDM bolt. It's the same F22/H23 bolt.
Go Tigers!
Taken from https://honda-tech.com/zero...ge=24
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">yeah I figured up the pitch and it IS pretty damn close... 20.320 to be exact
what grade is all-thread anyway? Mcmaster-carr sells studs too, I'm sure you could find a 7/16-20 one in whatever length that would be alot stronger.</TD></TR></TABLE>
haha yeah, I just got the 2' threaded rod. I'm kinda worried about the strength of it but I think I will be all right. Right now I just have a bolt in there with red loctite. I think it's a grade 5 bolt. I'm debating on whether or not it will become an issue further down the road.
Knowing that the M11-1.25 bolt is actually
11mm = 0.43307 inches diameter, 20.320 pitch
7/16 " = 0.4375 inches diameter, 20.000 pitch
Think it will be an issue?
want to just borrow my timesert kit and make it m11x1.5?
really, thats what I would do... the hell with trying to find a 1.25
Modified by pdiggitydogg at 6:56 PM 5/12/2007
al3e
12-14-2003 04:07 PM
