ECU question
ECU question
Does anyone know if can run an automatic ecu on a manual car?.......some people i talk to say that you can , others say no.........from what i have gathered, there is a way to convert an automatic ecu to a manual.......anyone heard of this?....if so, how is it done?......are there any write-ups?........thanks
Re: ECU question (purple98ek)
yes you can, but it will not run the way it should had you used the manual ecu.
this should help you:
https://honda-tech.com/zerothread?id=1977469
Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua »</TD></TR><TR><TD CLASS="quote">i was told you couldn't run it...well 2-1 ratio wins haha...</TD></TR></TABLE>
you can, i did on mine for a week while waiting on my ecu. i used a P06? it was off my SOHC automatic motor. it ran like ****, but it ran.
?? I ran my ecu unconverted for like 3 days... just had a check engine light and felt sluggish... Then I converted it and no check engine light.. I didn't feel any difference between my converted auto ecu and a manual ecu. When the check engine light was on (unconverted) it did run sliggish though.. I have 2 ecu's now. A converted auto ecu and a manual ecu.. my friend just gave me his old manual p06... Just wondering though.. does the ecu HAVE to be grounded? I've heard that from 2 people already. I just have it plugged in and tugged behind the carpet...
the ecu gets zero electrical connections from the mounting location. Everything is done though the harness.
the only issue that might arise is if something in the ECU is connected incorrectly and is touching the case, which may cause static problems. Then agian if it's connected like that inside the ECU, mounting it correctly will short what ever it is to ground and pop it... so I'm back to my original statement. it doesn't matter.
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the ecu gets zero electrical connections from the mounting location. Everything is done though the harness.
the only issue that might arise is if something in the ECU is connected incorrectly and is touching the case, which may cause static problems. Then agian if it's connected like that inside the ECU, mounting it correctly will short what ever it is to ground and pop it... so I'm back to my original statement. it doesn't matter.</TD></TR></TABLE>
Thank you
Thank you
