DIY - Rear Sub-Frame Brace
Well I thought I would document the progress of design for a rear sub-frame brace.
I have pre-liminary locations for the LCA Bolts, and the Sway Bar mounting locations. Next step is to cut a part and check fitment on the car. I will post more info and more drawings as dimensions are considered more accurate.
You may remember discussion about this DIY from this thread, which was a DIY for sway bar braces
https://honda-tech.com/zerothread?id=1940931
Modified by EG-Honda at 4:36 PM 5/9/2007
Modified by EG-Honda at 4:37 PM 5/9/2007
Re: (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 »</TD></TR><TR><TD CLASS="quote">Did you use CAD to draw that?
Looks good though </TD></TR></TABLE>
SOLIDWORKS
SOLIDWORKS
Re: DIY - Rear Sub-Frame Brace (EG-Honda)
Wow I'm going to bookmark this! If your EG subframe brace goes into production, I might have to splurge on some! You can ship to Canada right?
Re: DIY - Rear Sub-Frame Brace (radeonboy)
Curious to know why you need those 4 blank spaces or the horizontal beam? If you don't have those 4 spaces empty, wouldn't that help on strength of the whole frame?
Re: (Weel)
holy $h!t, resurection from the grave. I havent posted anything about this for a year!
Yes, I have been running this on my civic now for the last year, and the part is awsome.
I made it out of 1" thick aluminum, and the 1/2" thick brace is more than stiff enough. I also love the fact that my rear sway (19 mm) is located off my sub frame brace (no more worries). If you want to know that abuse I put it through, I Rallycross about 1 a month, and have also done 1 autocross, and 1 track day at Miller Motor Sports park. I also drive this car 70 round trip to work and back. It is holding up beautifully!
If you want one, I can make one for about $160...let me know!
Wow, back from the archives!
Re: (H22Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">how does this compare to an asr subframe brace and will it work with a larger swaybar
Could not say, I have never ran an ASR brace. That is why I made my own!
i want one that says **** on it
That could be done!
That could be done!
Re: (chimmike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike »</TD></TR><TR><TD CLASS="quote">somethin for us EK sedan guys?
looks good</TD></TR></TABLE>
Sorry, this was a home grown project. And I do not have access to an EK for development!
Re: (chimmike)
any brace for a 96-00 civic will work for you guys.
Re: (MrXclusivE)
Those spaces have been removed from the acutal brace. If you want to check the actual brace thread (finished product) go here: https://honda-tech.com/zerothread?id=2139492
And yes it has been tested, read earlier in the thread.
