turbo quick question
fisrt time going turbo on my ek d16y7 i have a b series down pipe will it bit my d exaust mani
my question is are the b series n d series dp the same
It does not matter whether its a D or B series motor. To be honest, it doesnt even matter what manifold you have.
The DP is attached to the exhaust side of the turbo....you need to make sure it has the same bolt pattern. Also depending on if you want A/C or not, will determine the "making" of the DP and the type of Manifold you use.
Hope this helps you...
