my Ek Has wierd stuff in radiator!!! LOOK
my ek (96 civic) dx.... just changed the headgasket becaouse the raiator kept getting full of nasty dirty water. i dont know exactly what it is but it keeps doing it. i changed the water everyday for 3 weeks and the car would still get hot and overheat. and the coolant keeps getting dirty. i havent drove it yet but i replaced the head gasket and torqued the head bolts down to 50ft/lbs. is that right? d16y7. Let me know whta you think could be the problem. help would be greatly appreciated!!!
Re: my Ek Has wierd stuff in radiator!!! LOOK (killacam661)
define dirty? do you see oil? have you checked your oil lately? Any leaks? You are correct on the torque spec on the head but did you torque it in steps?
Re: my Ek Has wierd stuff in radiator!!! LOOK (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 »</TD></TR><TR><TD CLASS="quote">
dirty water as in mikshakey? </TD></TR></TABLE>
yukkie
anyways im trying to upload a pic but my hosting thing is flaming right now but here goes:
step 1: 1-10 14 lb-ft
step 2: 1-10 36 lb-ft
step 3: 1-10 49 lb-ft
step 4: 1-2 49 lb-ft
here is the sequence
9 3 1 5 7
8 6 2 4 10
yukkie
9 3 1 5 7
8 6 2 4 10
Re: my Ek Has wierd stuff in radiator!!! LOOK (SiYouLater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiYouLater »</TD></TR><TR><TD CLASS="quote">Did you reuse the headbolts?</TD></TR></TABLE>
Im going to guess yes and since they are strecthed the head is not sealing properly and headgasket probally took a sh*t. Just a guess though
Are u burning anything? how do the piston tops look? if there shinny ur burning water, my guess would be a combination of blowin head gasket and use of oem head bolts, NEVER REUSE OEM HONDA HEAD BOLTS
Re: (burnitdown)
i used the same head bolts. its a stick, had alot of carbon build up on the valves,not to much black on top of pistons, other than that runs good now. there is a vacuum thing sticking out of the far right side of the intake manifold (DX). has ALOT OF SUCTION and when i plug it with my finger the car dies. what goes to that???
Re: (killacam661)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 »</TD></TR><TR><TD CLASS="quote">i used the same head bolts. its a stick, had alot of carbon build up on the valves,not to much black on top of pistons, other than that runs good now. there is a vacuum thing sticking out of the far right side of the intake manifold (DX). has ALOT OF SUCTION and when i plug it with my finger the car dies. what goes to that??? </TD></TR></TABLE>
You def. do not want to reuse the head bolts. They are a one time use thing. Should have got ARP's. Cheaper than OEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92’si »</TD></TR><TR><TD CLASS="quote">oh could also be your piston rings.. are you burning oil?</TD></TR></TABLE>
piston rings has nothing to do with dirty water...the water in the jackets should never come in contact with your rings. if it does you have bigger problems than dirty water.
did you send the head out to get resurfaced?
driving on a blown head gasket and constantly overheating it will cause the head to get warped.
Re: my Ek Has wierd stuff in radiator!!! LOOK (turbociviccoupe)
what id do right now as in tommorrow moring is drain the oil and check for coolant, flush the rad out one more time (just in case you didnt get all the crap out) and just keep trying to diagnose the problem alot of helpful info here man,
DO NOT ignore the problem itll just get worse
yea its like corrosion and stuff. te radiator cap get totally gunked up wit the ****. the head isnt warped got that checked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">
driving on a blown head gasket and constantly overheating it will cause the head to get warped.</TD></TR></TABLE>
correct.. need resurface
54
11-20-2008 12:39 AM
Nocturnal
12-06-2005 11:59 AM
