99 tail lights on 97
Re: 99 tail lights on 97 (tweetie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweetie »</TD></TR><TR><TD CLASS="quote">Would a 99' civic tail light fit on a 97' DX 2 DR civic? </TD></TR></TABLE>
bolts right up bro...no probs....
Re: 99 tail lights on 97 (nikeSBig13)
As long as you're talking about a coupe to a coupe or a sedan to a sedan. They are not interchangeable between the two body styles but same to same should be fine.
H-T White Ops
Re: 99 tail lights on 97 (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 »</TD></TR><TR><TD CLASS="quote">As long as you're talking about a coupe to a coupe or a sedan to a sedan. They are not interchangeable between the two body styles but same to same should be fine. </TD></TR></TABLE>
To clarify, '96-'98 coupes can have '99-'00 coupe taillights.
I should know. My '98 coupe has '99 Si taillights on it.
'96-'98 OUTER sedan taillights and '99-'00 OUTER sedan tailights are interchangeable. The inners require you to swap trunks.
'96-'98 hatch tailights and '99-'00 hatch taillights are interchangeable.
Re: 99 tail lights on 97 (NOFX)
It will work as good as its original tail light. 96-00 taillights are interchangeable the only difference is the amber corners on the 96-98's
H-T White Ops
Re: 99 tail lights on 97 (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 »</TD></TR><TR><TD CLASS="quote">It will work as good as its original tail light. 96-00 taillights are interchangeable the only difference is the amber corners on the 96-98's </TD></TR></TABLE>
Which means in order for the '99-'00 taillights to be legal, they must have an amber bulb in the turn signal.
thanks guys! I heard it will not completely fit, like there would be a small gap on the bottom? Is that true? Would anyone know where I would be able to get them? I was also thinking about changing my headlights also because it is old and turning yellow. Any recommendations?
Re: (tweetie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweetie »</TD></TR><TR><TD CLASS="quote">thanks guys! I heard it will not completely fit, like there would be a small gap on the bottom? Is that true? Would anyone know where I would be able to get them? I was also thinking about changing my headlights also because it is old and turning yellow. Any recommendations?</TD></TR></TABLE>
It will completely fit, no gap or anything, because my brother did it. You should able to get them on ebay about $120 or craigslist about $100. You should buy the CTR headlight for the JDM y0! or ebay black housing, but projector is a big nono on H-T. You can also sand the headlight, buff it with rubbing compound and it will look brand new.
