need help with b20 vtec
Old 05-09-2007, 03:40 PM
ekturbohatch22's Avatar
Default need help with b20 vtec
i have a b20b block and a b16 head. the b16 timing belt does not fit. what type of timing belt should i use and also what kind of water pump do i use.
Old 05-09-2007, 03:43 PM
spoon_ek9's Avatar
Default Re: need help with b20 vtec (ekturbohatch22)
any b20 or b18 will do. good luck on it, coz u might forgot alot more stuff if u can forgot timing belt is different length.
Old 05-09-2007, 04:08 PM
EKlp's Avatar
Default Re: need help with b20 vtec (spoon_ek9)
yup yup i just went thru it on my car i swap my car with a b20 vtec and there to many thing u need
Old 05-09-2007, 04:25 PM
spoon_ek9's Avatar
Default Re: need help with b20 vtec (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">if you use 22t water pump, use itr timing belt
if you use 18t water pump, use ls timing belt</TD></TR></TABLE>
what is the different between that 2 timing belt? is the tooth of the belt are different, then the cam timing would be off too.
Old 05-09-2007, 04:49 PM
Boostedb20EH2's Avatar
Get a b16 waterpump and gsr timingbelt for a crvtec.
Old 05-10-2007, 12:39 PM
The Si's Avatar
Default Re: need help with b20 vtec (Boostedb20EH2)
if your going b20v... get a GSR timing belt, GSR Water Pump, GSR Oil Pump
Old 05-11-2007, 07:25 PM
been there done that
doood's Avatar
Default Re: need help with b20 vtec (TheSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheSi &raquo;</TD></TR><TR><TD CLASS="quote">if your going b20v... get a GSR timing belt, GSR Water Pump, GSR Oil Pump </TD></TR></TABLE>
there is no difference between gsr, b16, or itr water pumps. and all 96+ b series oil pumps are the same thing.
Kirk@SyndromeAuto
25
10-09-2015 08:03 PM
kevin7200
03-30-2014 12:04 PM
1SickHb
10-04-2005 09:00 AM
gtturborex
09-23-2005 04:59 AM
88B20CRX
04-17-2003 05:23 PM
Quick Reply: need help with b20 vtec
