REAR DISC BRAKE CONVERSION
Seagull Management
Re: REAR DISC BRAKE CONVERSION (honvic21)
you need, the trailing arms, parking brake cables, and rubber flex hoses. If you are also upgrading the front brakes to integra units (this is actually what really gives you better braking, then you will need a 4040 prop valve from a non abs integra and either an MC and brake booster from a non abs integra, or a '91 EX master cylinder.
Davis Photography
yes you can. What I did was remove the actuator that is the part that engages on the spindle, just for peace of mind. I didn't want to hear a clanky sound every time it hit the ring gear going down the road.
2DoorBandit
12
07-07-2006 12:14 PM
