b17a1?
b17a1?
ok yet agin i have another question. i've come across a b17a1 motor for sale with a jdm b16 s1 trany, and i can't find anything on the b17a1 motor and for some reason my computer wont let me go to google. will this motor fit in my 94 civic and how much of a pain is it to do the swap? is it a good swap to do?
Re: b17a1? (josh94civic)
Here are the Specs for you... I have no clue if this will fit a 94 civ... from what I can see on the forums, it is possible but I am not sure what you'll need.
Acura B17A1 Engine JDM
Displacement (cc):
1678
Power (bhp@rpm):
160 @ 7,600 rpm
Torque (ft/lbs@rpm):
117 @ 7,000 rpm
Compression Ratio:
9.7:1
Bore (mm):
81
Stroke (mm):
81.4
Cam Design:
DOHC
Valvetrain:
VTEC
Displacement (cc):
1678
Power (bhp@rpm):
160 @ 7,600 rpm
117 @ 7,000 rpm
Compression Ratio:
9.7:1
Bore (mm):
81
Stroke (mm):
81.4
Cam Design:
DOHC
Valvetrain:
VTEC
if anyone can help me with weither it will fit in my civic or not i would appreciate it greatly. i mean it's a great deal it's the b17a1 gsr motor out of a 92 integra with bored .25mm over oversized ctr pistons, jdm itr head port and polished, all new b17 rods, new crankshaft, all new seals and headgasket, northodox racing pulley, ebay headers, throttle body spacer, jdm b16 s1 tranny with stage 2 clutch and lsd. all of the cvaxles and motor mounts computer and all for the swap.
Re: (MiMiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK »</TD></TR><TR><TD CLASS="quote">hydraulic transmission... out of a 92+ civic and 94+ integra w/ a b-series.</TD></TR></TABLE>
damn beat me to it lol. its a easy swap. with a little searching and mechanical skills you can do it.
Re: b17a1?
B17 was from the 3rd gen Integra GSR. As said, it's a stroked B16 with a special crank, rods, pistons for just that engine. The block and head are normal B16 parts.
Mechanically it's bolt in, electrical you may need to get a distributor to match your generation of car (obd1 for 92-95 for example). Injectors you may need to check on.
Re: b17a1?
the first gen gsr is obd1. dizzy will be plug and play. wire up vtec and i believe a knock sensor and you're good to go.
a hydraulic clutch is similar to hydraulic brakes in it uses a hydraulic piston with a reservoir full of brake fluid to move the clutch arm vs a cable clutch which like a motor cycle uses a a mechanical cable that attatches to the transmission from the clutch pedal.
while the motor is special, the swap is not any different from any other b series swap
Crazy Honda Guy
dls_tech
18
07-30-2011 05:00 PM
Corksil
29
08-30-2009 07:07 AM
94_civicEx
19
07-10-2003 10:23 PM
Hard2Find
12-12-2001 07:33 PM
