Civic eg fix
92 Hatch. Help this build get started!
Hey new to the forum, I previously had a lude lol.
So I traded it for a 92 cx hatch with a d16z6 swap. The problem is, Its throwing 4 codes.. I know i know search but I did. I'm planning on turbo'ing it and its already set up for one when I got it.
They are:
IACV
Fuel Injectors
Electrical Load Dectector
Egr system
It idles pretty high and rough until it warms up and then its fine. I've already cleaned the iacv, it looked pretty clean.
But it has 440cc injectors in it now and I assume the clips from the wiring harness wouldn't fit so there are different clips soldered into the F.I harness.
Sorry for the stupidity but can anyone help?
Here are some pics anyways:
Modified by z6htch at 2:03 PM 10/2/2008
They are:
IACV
Fuel Injectors
Egr system
Seagull Management
Re: (z6htch)
Whats in it for an ECU? the fact that its throwing an EGR code (which the D16Z6 doesn't use, neither does the D15B8 originally found in the CX) suggests to me that someone put a P07 out of a VX in there. Correct ECU would be a P28.
the ecu is a p28 i checked. but about the code, that is just what the guy told me when I traded him.
And he said since there was going to be a turbo, I would need an egr block off plate?
Sorry about that, I'm new to the whole turbo thing
crowscare
09-23-2012 09:43 PM
