Popping a fuse......
Hey guys well to start, i just finished changing my clutch and when i drove my car, the speedo wasnt workn. I checked the sensor and it seemed ok and i checked the in-dash fuse box and found that the Alternator sp sensor fuse (no clue wat that means) blew, i just changed it and it blew again, any suggestions,
check all your grounds, and make sure theres no + wire hitting the chassis.
you might have forgotten to put a ground wire back on when you put everything together after the clutch change
Re: Popping a fuse...... (BlueIntegraBoy)
im not sure, just my o2 wire got banged up but its ok but i'll check on that, could someone post up a wiring diagrahm that goes from the alternator sp sensor in the in-car fuse box.?????????
Re: (SiREJ8)
2000 civic ex(stock d16y8) i/h/e pulleys, any info on the ALTERNATOR SP SENSOR located under the dash(the fuse box) that fuse seems to keep popping???????????????????????????????????
Re: (si_motor_spt)
u banged up ur o2 wire... make sure they r all in good condition i had this problem for a month i couldnt figure it out. i hit a rock in the road and it broke 1 wire on my secondary o2 and i never knew and my battery light came on cause it blew my alternator sensor fuse which basically my car wasnt recognizing my alternator. i tried everything and replaced my alternator and battery and then i finally found the blown fuse and replaced it and it kept blowing so i called my tuner and had him look at a wiring diagram and he said look at ur o2 wire for the hell of it cause its exposed so i looked and it was slightly broken and i ended up unplugging it b/c i am now obd1 and i replaced the fuse and bam... car was fine... stupid wire gave me a headache for a month.
