what hose goes here on the back of the gsr block?
Re: what hose goes here on the back of the gsr block?
Pic was taken wit my phone can try o make it bigger but idk...n ya it's above the oil filter but I've never seen one before on ne of my other b18 blocks
Re: what hose goes here on the back of the block?
yup dont trust fram at all. wix is one of the best one found at napa. 100% more trustworthy http://www.youtube.com/watch?v=rIx4Y3TvAPk
Thanx So I should jus be able to plug it off cause I have no a/c controls in my car and as far as the nipple next to idk that's how it was when i got it
sorry i thought the filter was on the right side. that connection is for the oem oil cooler which is removed for whatever reason on your motor.
Crazy Honda Guy
PS- it looks like in your pic (hard to see, that that engine has an aftermarket sandwich plate mounted in behind your oil filter)
When u say loop the line wich lines are u talking about and what would a 96-01 water pipe do for me cause I have one off my old ls motor
So basically I gotta get a stock oil cooler??can I jus plug it or is it needed to have?
#1 Super Guy
This oil cooler is standard on P72 block motors (GSR & ITR and CTR). They didn't come on the B16As (at least in the US). You can't really install one if you've already got a sandwich plate, but you should probably run an external oil cooler instead. Especially if you are turbo.
ActiveAero
10-02-2005 05:03 AM
Vsm Hatch
08-26-2004 07:16 PM
