help!! vent keeps on opening...
hello! i just installed a new stereo in my ek few weeks ago and i noticed that my vent keeps opening everytime i restart my car.. what must be the problem? please advice. thank you!
Re: help!! vent keeps on opening...
i dunno i just noticed it after i installed my stereo.. maybe when we wired my stereo or something.. seems like it doesn't remember my old settings.. for example before i turn off my car i closed the vent. when i start my car the vent opens by itself..
um.. just the one that goes to the radio.. but i used the spare power wire by my fuse box below my steering wheel.. would that be the reason?
The Grumpiest
I have no idea what you're talking about. Did you hack the wiring or did you use a proper adapter harness to install the new deck?
With these you don't splice into anything.
The Grumpiest
Which is it? You used a harness or you spliced into "the spare power wire by my fuse box below my steering wheel"? If you used a harness you wouldn't be having this issue IF the problem is actually related to your deck install.
i was having problems with the stock power wire (the wire the is included with all the wires behind the radio area) so what i did is i used the spare power outlet (sorry i dont know what exactly they call it) by the fuse box below my steering wheel to power up my radio.
no power. when i used my tester it doesnt read 12v. sorry sir im realy bad with wirings.. but thank you for your patience..
um.. theres a plug by the fuse box below my steering wheel that you can get power. so what i did is i used that to power up my radio.
The Grumpiest
This has got to be coincidental. I don't own a 2000 but I don't see how these two systems are interconnected. Possibly you should just concentrate on the climate control system.
ok. but i didnt do anything on that one. its just disconnected it when i installed the radio. thats why im thinking coz i rewired my power wire maybe it was affected or something. btw, i also tried a different climate control system and still it didnt stay on the setting before i turned my car off.
Thats weird they didnt keep using them in the 01 civics... possibly a short you moved and made contact with something else while moving wires around. possibly theres a reason they didnt keep using them after 2000... can you pull the fuse for it and see if they stay in there spot.
Ashlyn26
18
06-29-2016 06:44 PM
