rear disc conversion: weight?
Old 01-27-2005, 05:00 PM
I forgot more about hondas then you will ever know....
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
Default rear disc conversion: weight?
anyone have a rear disc setup they have kicking around that you can throw on a scale? i am curious what the disc setup weighs. i prefer actual weight, not "dizzamn that **** is like 50lbs yO!"
i just got a drum setup, and i would like to know if the disc setup is lighter or heavier. i searched and got conflicting reports. thanks.
Old 01-27-2005, 05:02 PM
Unceasing Measure
Archidictus's Avatar
Default Re: rear disc conversion: weight? (rodney)
I'm positive the discs weigh more, but by how much I'm not sure. Bump for a good question.
Old 01-27-2005, 05:08 PM
Rodney's Avatar
Default Re: rear disc conversion: weight? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I'm positive the discs weigh more, but by how much I'm not sure. Bump for a good question.</TD></TR></TABLE>
i will find out in a few weeks, but i am dying to know right now. i am converting back from 5 lug, and will weigh every step of the way.
Old 01-27-2005, 05:11 PM
jlacoy82's Avatar
20-21lbs for the hub/rotor/caliper with rubber brake line and axle nut attached! (one side)
This is from a 95 GSR.
(Yes I just happened to have these laying around, yet to put them on. )
Whats the weight on the drum btw?
Old 01-27-2005, 05:15 PM
Rodney's Avatar
Default Re: rear disc conversion: weight? (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">20-21lbs for the hub/rotor/caliper with rubber brake line and axle nut attached! (one side)</TD></TR></TABLE>
hmm... i assume that is not with the trailing arm, correct?
Whats the weight on the drum btw?</TD></TR></TABLE>
35.20 lbs with trailing arm/e-brake cable
Old 01-27-2005, 06:07 PM
hayabusa160's Avatar
i can weight my 5 lug rear lol just got it but i dunno. u prolly looking for 4 lug
Old 01-27-2005, 06:14 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: rear disc conversion: weight? (hayabusa160)
Give me two minutes.
Old 01-27-2005, 06:20 PM
litterbox's Avatar
Default Re: rear disc conversion: weight? (litterbox)
Front: 37-38lbs
Rear: 38lbs
(Edited. See below)
Fronts include spindle and everything attached.
Rears include trailing arm and everything attached.
Modified by litterbox at 3:41 PM 1/28/2005
Old 01-27-2005, 11:31 PM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Front: 33lbs
Rear: 34lbs
Rears include trailing arm and everything attached.</TD></TR></TABLE>
nice! so they are basically just under the drums. i guess i'll just stick with the drums then. thanks litterbox.
Old 01-28-2005, 10:36 AM
JokerTypeR's Avatar
Reading this I'm seeing all types of numbers. I've got a 91 with rear drums and I'm looking to convert to the disc setup. Obviously it's a 4-lug patter (4x100 if it matters) I've heard the DRUM was less weight? I'm doing the rear disc despite the weight due to sliding purposes ( ) but I"m still just curious for the mythbust...?
Old 01-28-2005, 10:49 AM
Rodney's Avatar
Default Re: rear disc conversion: weight? (JokerTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote"> I've heard the DRUM was less weight? </TD></TR></TABLE>
i have heard the same thing. guess i'll weigh a friends rear disc setup (not for a few weeks) and compare that to my 5 lug setup as well. also, it is my understandng (again, total hearsay as i never weighed the parts myself) that the ef drum setup is lighter/smaller then the eg/ek. i will post my findings soon.
Old 01-28-2005, 11:00 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">i have heard the same thing. guess i'll weigh a friends rear disc setup (not for a few weeks) and compare that to my 5 lug setup as well. also, it is my understandng (again, total hearsay as i never weighed the parts myself) that the ef drum setup is lighter/smaller then the eg/ek. i will post my findings soon. </TD></TR></TABLE>
What i weighed was a front and rear setup off a '00 teg. The scale I used was an old bathroom scale. I tried to calibrate it as best I could, but it might be a little off. My drums are presently on my car so I can't compare.
Old 01-28-2005, 11:01 AM
JokerTypeR's Avatar
Nice. Yeah, I mean I don't care so long as the scales accurate +/- 2 or 3 pounds. If it's on the same scale then accuracy Id on't give a ***t about.
Old 01-28-2005, 11:09 AM
Unceasing Measure
Rear: 34lbs
Unreal! The discs are seriously lighter by a pound? Damn...every single person I've ever asked has told me that the discs weigh significantly more than the drums.
Learn something new every day .
Old 01-28-2005, 11:12 AM
memoryFAB.com representative
spock_rocker's Avatar
[QUOTE=Archidictus]
QUOTE]
i was told the same.. well it makes me want to get them even more now!
Old 01-28-2005, 11:19 AM
JokerTypeR's Avatar
Default Re: rear disc conversion: weight? (spock_rocker)
If you don't already know, check local salvage yards for these. Ebay is usually more expensive. Or search on here...
Old 01-28-2005, 11:31 AM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Nice. Yeah, I mean I don't care so long as the scales accurate +/- 2 or 3 pounds. If it's on the same scale then accuracy Id on't give a ***t about.</TD></TR></TABLE>
i will be using a ny state certified digital scales for all my weights. i will let everyone know what i find.
Old 01-28-2005, 11:32 AM
JokerTypeR's Avatar
...well aren't you special LoL. It's all good though. I just want numbers
Old 01-28-2005, 11:38 AM
litterbox's Avatar
I re-weighed the front and rear discs.
Front: 37-38lbs
Rear: 38lbs
(I think my first readings were off because of the way I was holding the pieces up on the scale)
Here are pics:
Old Bathroom Scale (calibrated to 0):
http://www.we-todd-did-racing....D.jpg
Front 10.3'' (off a '00 LS Teg)
Rear 9.4'' (off a '00 LS Teg)
Old 01-28-2005, 11:56 AM
JokerTypeR's Avatar
Excellent shots. I wouldn't imagine it'd be too off from the 93-97 (I think...) would it?
Old 01-28-2005, 04:42 PM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">I re-weighed the front and rear discs.
Front 10.3''
Front: 37-38lbs
Rear 9.4''
Rear: 38lbs
okie, that sounds more like it. my 99 civic dx (9.4 fronts, drum rear) is 33.2 for the front and 35.2 for the rear. tomorrow i will be weighing a set off a 98 teg front and rear, then this sunday my ITR setup. so i will let you know my findings.
boostedbatch
10-03-2010 01:31 PM
TsujenDB1
02-22-2007 10:13 AM
d16vteceg
11-20-2005 03:05 PM
Race Egr
01-12-2005 03:22 PM
AzntaggeR
03-25-2004 01:49 PM
Quick Reply: rear disc conversion: weight?
