code #8 civic eg
Re: code #8 civic eg (ThisLittleSleepeR)
Top Dead Center Sensor (TDC Sensor). It is in the dizzy, and you can't buy it seperate. Get a new dizzy
Modified by PLANBmotorsports at 4:43 PM 1/27/2005
Re: code #8 civic eg (PLANBmotorsports)
so i need a whole new dizzy? whould that be the reason i have a weird idle when cold, and when i just go sometimes the rpm's would fall? been like this for a long while, im finally getting irritated with it.
1 Post
just replaced a distributor that had the TDC sensor break off from it's mount.car ran just as you've described.this tells the ECU where the motor is in it's rotation-it being broken can certainly lead to the distributor firing at the wrong time causing problems like you have.
before spending money on a a new distributor,troubleshoot your current one.in a a shop manual there's a procedure to test the sensor itself,and you'll also want to test the wiring to make sure there are no shorts or breaks anywhere.
Chris
Chris
I just had the same problem #8 code. I just replaced my LS distributor. Got a new housing for $125 (Acura-Honda) and it runs great.
sebTeggy
10-21-2011 09:28 PM
crxnonvtec
08-20-2009 02:40 PM
turboxsi
06-10-2003 03:32 PM
sander
04-25-2003 07:46 AM
