Fogged windows in 92 VX
This is my first winter with my VX and I frequently have problems with all the side windows becoming overly fogged up (to point of frost forming) while driving despite running defrost. Has anyone/does anyone else experience this same issue?
Re: Fogged windows in 92 VX (Lamb)
Take your heater off the circulate setting, they will clear up for you. I've had the same problem this winter, and changing the setting works great. I've heard windexing your windows helps as well.
Is there a film on the windows? kinda' oily film. It could be a leaking heater core and with the defroster on it may be getting some coolant on your windows. Check your coolant level, if its low that may be a concern. good luck!
Re: Fogged windows in 92 VX (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon »</TD></TR><TR><TD CLASS="quote">Take your heater off the circulate setting, they will clear up for you. I've had the same problem this winter, and changing the setting works great. I've heard windexing your windows helps as well.</TD></TR></TABLE>
I'll try that next time. Thanks for the tip.
Re: Fogged windows in 92 VX (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">I use this:
Rain-X anti fog. It works very well</TD></TR></TABLE>
Regular Rain-X kicks *** too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote"> Regular Rain-X kicks *** too. </TD></TR></TABLE>
I was saying the both kick ***.
EGhatched
11-19-2003 09:29 PM
