90/91 Integra Axle vs. 92/93 Integra Axle in H22 EG hatch
Old 11-06-2005, 06:28 PM
T
Default 90/91 Integra Axle vs. 92/93 Integra Axle in H22 EG hatch
Okay I have an H22 EG hatch. My axle keeps popping out on the passenger side. I replaced it with a brand new 92/93 integra axle. The previous axle was a 90-91 Integra axle. DO you think that the fact that I used a newer axle instead of the original older axle that I'm having this problem?? Wouldn't the axles be the same all throughout the years, (90-93) considering its the same chassis???
Old 11-07-2005, 08:29 PM
RaceCarRyne's Avatar
Default Re: 90/91 Integra Axle vs. 92/93 Integra Axle in H22 EG hatch (H22+EG=12sec killer)
first of all did you have an axle nut on it??? plus there is a difference between abs and non abs axles.. i alslo know that 90-91 trans have a larger out put shaft on the trans.... just check for the abs thing...
Old 11-08-2005, 05:02 PM
B A N N E D
VNTEC's Avatar
Default Re: 90/91 Integra Axle vs. 92/93 Integra Axle in H22 EG hatch (DC2jdmIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2jdmIntegra &raquo;</TD></TR><TR><TD CLASS="quote">first of all did you have an axle nut on it??? plus there is a difference between abs and non abs axles.. i alslo know that 90-91 trans have a larger out put shaft on the trans.... just check for the abs thing... </TD></TR></TABLE>
The 90-91 output shaft is irrelevant to the axles, it only affects which clutch disc u will be using. The ABS thing is also irrelevant, unless the car is equipped with ABS from the factory the only difference between abs and non abs axles are the fact that the ABS Axles have a pick up ring at the end of it, but other than that they are virtually the same
JDM***CD6
04-08-2011 12:19 AM
vdubsduncutit
13
06-02-2010 05:00 PM
T"u"Rtle
11-06-2005 08:39 PM
sir2k
07-13-2004 09:27 AM
Quick Reply: 90/91 Integra Axle vs. 92/93 Integra Axle in H22 EG hatch
