adjusting fuel pressure
how do i do this and what should it be set at. the motor is a b16a. will i be able to affect how lean/rich my car is running?i need to pass emissions and was wondering if i could adjust this temporarily to get my car to run leaner. right now it is set just under 40...
Re: adjusting fuel pressure (pompom)
You can't adjust it unless you have a FPR.
Most of the stock FPRs are set around the 40-42 psi range.
Do you have a wideband? Don't go ******* with **** unless you know where your AFRs are at because if you guess wrong & turn it down too far you'll lean out the car & you'll have to worry about seizing you block/melting a piston.
It sounds like it's at the stock pressure. Why won't it pass emmissions as-is?
Re: adjusting fuel pressure (Everyones Hero)
i dunno, can i adjust it in anyway possible to lean the car out?its running really rich right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pompom »</TD></TR><TR><TD CLASS="quote">i dunno, can i adjust it in anyway possible to lean the car out?its running really rich right now.</TD></TR></TABLE>
You can't lean it out unless you get an adjustable fuel pressure regulator.
How do you know it's running rich?
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">You can't adjust it unless you have a FPR.
But he does have an FPR
Maybe an adjustable one will help
(stocks are not adjustable OP)
cute little bastard
Re: (pompom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pompom »</TD></TR><TR><TD CLASS="quote">k well i think mines adjustable, if i want to try to lean it out what should i do?</TD></TR></TABLE>
I wouldn't recommend leaning the engine out, but w/e lol
Pull off the vacuum hose on top. Loosen the top bolt (I think its a 10 or 12mm) then grab some pliers and turn the piece where the vacuum line was attached to (I don't know if its clockwise or counter, but hopefully you have a gauge so you know which way you're going) and tighten the bolt back up and put the vacuum back on.
Re: (SkoundrelUSA)
so will lowering the pressure richen or lean the car out?also, why dont you recommend it?would it be safe if the was only ran that way for 15 minutes and then id switch it back to just under 40..
Re: (pompom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pompom »</TD></TR><TR><TD CLASS="quote">so will lowering the pressure richen or lean the car out?also, why dont you recommend it?would it be safe if the was only ran that way for 15 minutes and then id switch it back to just under 40..</TD></TR></TABLE>
Lowering the pressure will lean the motor out.
I'd just leave it at 40 and go. If it's at the stock setting it shouldn't be running rich at all. It should be running stoich (around 14.7). Is this a stock motor running a stock ECU?
Why do you think it's running rich?
cute little bastard
Re: (pompom)
Lowering the PSI will reduce the amount of fuel hence leaning it
I just don't like the idea of an engine running really lean. But hey its your motor dude.
Location: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Re: (pompom)
Is it a stock motor? How do you know the motor is running rich? There is a # on the side of the ECU that tells you what it is..
blue_hatch
03-06-2005 11:39 PM
