engine shut off at light!
so i was at a light last night and the car had been runnig fine. No impending warning of trouble or anything and then in the blink of an eye the oil light and cel come on at the same time and the car shuts off immediately. I got the car pushed to the side. I checked the dip stick and the oil is low but when i go to turn the car on the fuel pump wont prime. I usually hear it very well. So i took the backseat out to make sure I could hear it and nothing. The car cranks over like a champ but doesnt start. any suggestions?
Re: engine shut off at light! (wifesaynogo)
well obviously you're not getting fuel. Chances are there isn't a code. I'd begin by checking fuses obviosly and then checking the PGM-FI main relay. After that i'd check to make sure the pcm has powe and ground and is functioning properly. Then test the fuel pump, and it's wiring and go from there.
Re: engine shut off at light! (JDMFantasy2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">well obviously you're not getting fuel. Chances are there isn't a code. I'd begin by checking fuses obviosly and then checking the PGM-FI main relay. After that i'd check to make sure the pcm has powe and ground and is functioning properly. Then test the fuel pump, and it's wiring and go from there. </TD></TR></TABLE>
what he said...
what he said...
Re: engine shut off at light! (JDM_Ej)
oh yeah i found the short to i just didnt state it. one of the terminals on my fuel cut off switch came loose and touched the chassis shorting the fuse...its all taken care of
billy hoang
12
04-11-2009 07:54 AM
nemeii
23
08-10-2008 03:10 PM
jay-tec
10-26-2007 08:24 AM
