car iddling problem need some help!
Old 09-15-2006, 05:51 PM
3k9civic's Avatar
Default car iddling problem need some help!
first it take a few crank before the car turns on. but after it turn only it iddle around 2k. the big problem im concerning is when i give it some gass, the rpm decrease and then slowly die? does anyone know anything about this? i would be apreciated if you guys can share some experience
Old 09-15-2006, 06:01 PM
TeamNextGenChris's Avatar
Default Re: car iddling problem need some help! (3k9civic)
any trouble codes?
https://honda-tech.com/zerothread/1171263
chris
Old 09-15-2006, 07:25 PM
Jonknee's Avatar
Default Re: car iddling problem need some help! (TeamNextGenChris)
ah i have the same **** problem, it will start, and slow act like its dying and then reach normal operating status, and once i give it gas it will decrease in rpm. And when im driving under 3000 rpm its slow as *****.
My theory- Im running rich due to bad intake temperature sensor. Maybe it is the same problem for j000
Old 09-15-2006, 08:45 PM
jdeemseerx's Avatar
check if you have any codes.. also try cleaning the throttle plate and throttle body that could be a result of carbon build up, i mean it could be alot of things but give the cheap things a whirl first
ITR010342
Acura TSX
06-23-2010 08:45 AM
redraven_k6
04-19-2010 09:07 PM
djtony5
08-21-2005 02:42 AM
wicked013
03-09-2004 03:46 AM
Quick Reply: car iddling problem need some help!
