ITR header on B16EG hatch???
Old 04-01-2003, 02:18 PM
SOHC_DK.'s Avatar
Default ITR header on B16EG hatch???
Will the ITR header fit on my EG6. It's the one with the stock B16A2 engine..??
I am planning on buying a Supersprint ITR performance header, because it's just a little bit bigger than the one they make for the B16.. and it's just a little to small I was told...
Thanks....
M. Nielsen, Denmark
Old 04-01-2003, 02:25 PM
fowler!'s Avatar
Default Re: ITR header on B16EG hatch??? (SOHC_DK.)
Yes and no.
It will bolt up fine, no need to worry about that.
But you need to take into consideration two things.
1. It hangs a little bit lower than a stock B16 manifold. So, you can't be lowered too much.
2. It has a 2.5" collector. So, you'll need to modify or replace your cat with something that will work.
Old 04-01-2003, 02:32 PM
SOHC_DK.'s Avatar
Default Re: ITR header on B16EG hatch??? (fowler)
Hmmm... my car is lowered pretty much... and the cat shouldnt be a problem, because I am buying a replacement cat without flanges (??) so it will be costum made for the header...
ef8-dc2619
06-27-2007 06:24 AM
silver ek
04-10-2004 12:41 PM
HYREV2NR
08-13-2003 10:59 AM
lude69
07-30-2002 09:43 PM
Timmayeg
02-21-2002 12:15 PM
Quick Reply: ITR header on B16EG hatch???
