ECU reset
Re: ECU reset (97hb)
You could just pull out the fuse thats in the fusebox in the engine bay. I believe its the radio back up fuse. There was an article awhile back that claims the computer will relearn with the new mods giving better performance.
Re: ECU reset (Panda EK)
here's what i read A LONG TIME AGO:
pull the ecu fuse along with the back up fuse, leave it out for 1min -2min, turn the ignition key to make sure to drain all of the electric current(easier to just unplug the ecu!!). plug back the fuses and start the car without stepping on the gas. leave it on for a good 1min. turn off the car. start it up again 30sec-1min and floor it/rev it.
that's what i read in honda-tuning or something like that a long time ago. seems to 'kinda' help.
Re: ECU reset (shermanyang)
yea what i heard was to pull the ecu fuse from under the hood, making sure you turn ignition to (2 clicks) then disconnect the battery for a few minutes, then reinstall everyhting, and then start car and let it run for like 5 minutes idle!
OpTiX619
05-14-2005 10:05 PM
