help need on type r manifold install...
I just installed my type r manifold, i use the type r fuel rail and injectors.
this on a 95 b16a. I notice the clips are different, im think its a obd2 clips.
can i just clip my oringinal (4)fuel injector clips and butt connect the obd2 clips on ?
thanks
thanks
Re: help need on type r manifold install... (hoacun)
Yes, you can wire in OBD1 injectors to an OBD2 engine wiring harness if you use the OBD1 connectors spliced into the OBD2 harness. Or vice versa. Just make sure that you make your connections tight, because a bad connection will cause a misfire and loss of power.
