clutch makes a scraping noise when i let it out ?? why?
it sounds like a piece of metal rubbing on something or a spring being stretched from the clutch area. it just started lately.. what could this be? its a 93 SI hatch.
Re: clutch makes a scraping noise when i let it out ?? why? (civicracer1993)
Squeaking noise, or more of a rubbing sound? It's probably your release bearing (Is that the same as the throw-out bearing?). Common problem, but you have to drop your tranny to replace it. They're only about $10, but if your going to go through the trouble, then you might as well replace the clutch while your in there. Most clutches come with these bearings.
thatdamngood
12
03-17-2004 09:03 PM
Cosworth
08-23-2002 03:02 PM
