Has anyone swapped a 92-95 D15B7 for a 96-97 D16Y8?
What did you as far as vacuum and coolant line connections on the intake manifold and throttle body? I know several connections are different between the D15 OBD1 manifold and the Y8 OBD2 manifold. Also the charcoal canisters are different. The D15 has a hose going from the charcoal canister up to a connection on top of the throttle body. My 94 B18C1 has this same line. However the Y8 throttle body does not have this connection.
The D15 throttle body has a separate fast idle thermo valve w/ coolant lines below the TB opening. The Y8 throttle body has 2 coolant line connections below the TB opening, but there does not appear to be a separate thermo valve. Is it integrated into the TB in some way?
Need help from any one who has swapped an OBD2 Y8 engine or even just a Y8 intake manifold into an OBD1 chassis. TIA
[Modified by PatrickGSR94, 10:37 PM 4/1/2003]
Re: Has anyone swapped a 92-95 D15B7 for a 96-97 D16Y8? (PatrickGSR94)
come on, nobody has done this? Are we pioneers here, the first one to do it??
i'm going to do this to but i'm looking for the info somewhere here on this dang internet. haven't found much.
thebleek
09-04-2008 01:43 PM
turboman
05-31-2005 03:42 PM
