How do you remove the rear seats?
Old 04-02-2003, 05:09 AM
151 Proof's Avatar
Default How do you remove the rear seats?
Anyone know how to remove the rear seats in a 5th gen coupe? I need to install a new fuel pump.
Old 04-02-2003, 07:23 AM
Patron's Avatar
Default Re: How do you remove the rear seats? (151 Proof)
First you need to remove the plastic clip that holds the upper half of the seat to the interior panel, after you have that removed, it should slide about an inch to the interior panel, then the top half should pop off. Repeat for the other side. Bottom half is held on by 1 bolt. Remove the bolt, then proceed to lift the bottom half of the seat up, pull from the rear of the cushion up. It should be vertical, now wiggle the seat till it comes out.
Old 04-02-2003, 09:26 AM
151 Proof's Avatar
Default Re: How do you remove the rear seats? (ptran13)
Thanks.
sethrd
Honda Civic (2001 - 2005)
08-27-2008 09:27 PM
fastboy501
11-29-2005 09:28 PM
camelian
08-18-2005 08:37 PM
optikal_blitz
01-29-2003 02:09 PM
Fuster_Cluck
12-16-2002 09:33 PM
Quick Reply: How do you remove the rear seats?
