EG d15.... why do I blow up so many power steering pumps ????
I have a VX (d15z1) swap in my 1995 LX sedan.
I've tried to use 2 different power steering pumps, and both times they end up smoking (smell of burning PS fluids) and leaking fluids out of the 4 bolt plate.
I bought a new belt & am 98 sure it's the correct tension on the belt.
<FONT COLOR="green"> What can cause PS pumps to go bad?
--- Do i need to bleed the PS system or something?
</FONT>
</FONT>
Re: EG d15.... why do I blow up so many power steering pumps ???? (Charlie Moua)
<FONT COLOR="red"> didnt know the VX was strong enough to turn the pump
bump for you </FONT>
<---has the Z1 curse
Re: EG d15.... why do I blow up so many power steering pumps ???? (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red"> didnt know the VX was strong enough to turn the pump
<---has the Z1 curse</TD></TR></TABLE>
hhaha
yeah it's slow as heck in my 2400lbs eg sedan.
but yeah, I just put my old LX ac, power steering bracket stuff onto the VX block.
but now am having issues with the pump.
hhaha
Re: EG d15.... why do I blow up so many power steering pumps ???? (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Are you using genuine Honda PS fluid? ATF doesn't work.</TD></TR></TABLE>
some other stuff, non oem...
why is there a difference?
Honda PS is pretty different from everything else. Even at the auto parts store they sell generic "made for honda" ps fluid. Why is there a difference? It's Honda
Re: (B20 EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 EJ6 »</TD></TR><TR><TD CLASS="quote">The pressure hose is probably collapsed, causing little to no fluid movement which in turn is burning your pump.</TD></TR></TABLE>
<FONT COLOR="red"> Ok guys I'll run to honda and get some PS fluids.
What hose is collapsed? also how can you test to see if it is working or not? </FONT>
Re: (Charlie Moua)
i dunno the collapsed hose is def a thought but its a hydraulic hose and seriously doubt it went bad but def a possibility i would try teh fluid first
bonbon
04-10-2004 02:19 PM
