I will paypal $10 to who ever can answer this swap question.
I just did a 00 gsr swap in my 95 cx hatch, i used the obd2 harness and ran the vtec and knock wires and also added the tach wire to the harness. for some reason the alternator isnt charging. i had it tested and its fine. i checked the connector as well as the other wire and they are ok. what else can i check? i also checked the fuses and did a continuity check on the four alt. wires
Re: I will paypal $10 to who ever can answer this swap question. (roma's h22eg6)
Check your grounds. Make sure the alternator is grounded where it meets the motor. Thats my only ideas
Did you have the battery checked when they checked the alternator? The alternator can be fine but if the battery is bad it will not charge.
jdm 1080p
03-28-2012 02:11 PM
93civiccxhatch
08-24-2004 07:57 PM
