ITR Sway in EK hatch?
Just curious what is needed to fit an ITR rear sway in an EK hatch?? Will I need a ASR subframe or can the stock subframe handle 22mm without tear-out?
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">yes, you need bracing like the asr piece or full comptech</TD></TR></TABLE>
you mean something like this?
http://cgi.ebay.com/ebaymotors...&rd=1
Re: (o2flow.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o2flow.net »</TD></TR><TR><TD CLASS="quote">what about the front? Can I use an ITR sway in the front also?</TD></TR></TABLE>
NO!!!!..... but you can use OEM Si/CTR (they are the same) sway 26mm
Re: (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">NO!!!!..... but you can use OEM Si/CTR (they are the same) sway 26mm </TD></TR></TABLE>
sweet, does it bolt right up or do I need hardware?
Re: (o2flow.net)
sweet, does it bolt right up or do I need hardware?</TD></TR></TABLE>
you need Si front LCAs, forks & D-brackets with bushings then it will bolt up....might as well get '99-'00 si F&R brakes too
.:Made in OC:.
13
02-20-2007 04:05 PM
Airbag Club
Northern California (Sales)
10-01-2006 07:35 PM
