rumors need to be cleared up...
Guest
Posts: n/a
i am hearing too many things about the b16 and b18b...
A b16 turbocharged at about 5500 rpm(vtec engagement) will fight with the boost from the turbo and they will cancel each other out and also the driver will experience hesitation from the vtec and turbo engaging...next i hear the b18b is the one the best motors to run turbo with...I plan to do a motor swap in april-may 2003 and i just wanted to get as many opinions as i possibly can about this subject...
New User
Re: rumors need to be cleared up... (civicman)
Uh, I dont know who you get your info from, but my buddy is running a B18C bottem end (fully built) and a B16A head (Bone stock) and he pulls low 11's at 5000 feet above sea level.
1 Post
what kind of ECU are you using on the swap. in some cases. such as the OBD2 turbo install in the 98+ prelude with the traction control (SH model). there is a hesitation when the map sensor detects boost. it starts trippin out when the Map and the ECU and the traction control computer try to control everyting at the same time.
so in some cases yes, it will have that kind of hesitation, but in most cases, expecially pre-obd2 swaps, Map sensor probs are solved by adding more check valves or using a Missing Link.
Wil
Wil
Former Moderator
Re: rumors need to be cleared up... (Zer0DazE)
Bottom line:
VTEC + Turbo = MORE power.
Take equally boosted B16a and B18B and the B16A will outpower the B18B and the car will be quicker. The B18B will make more torque, but it still won't compare as well in terms of power because the sheer head flow of the B16A is much better than the non-VTEC head.
This isn't to say that boosted LS motors can't make good power, but they are not any "better" for turbo in terms of power output and drivablilty.
Re: rumors need to be cleared up... (B18C5-EH2)
I swear to God 99% of Honda owners don't know what VTEC is. Can someone please try to scientifically explain how VTEC is BAD for a turbocharged engine? You CAN'T because It's actually a lot better. If you don't believe me go ask GSRwBOOST, I'm sure he can set you straight.
In my opinion, I think VTEC is an excellent thing for a turbocharged engine. It's like icing on a cake.
P.S. Listen to B18C5-Eh2 he knows his stuff....
Former Moderator
Before any of the Einsteins chime in with:
"...but Jojo Callos and the 9 and 10 second cars actually cancel out their VTEC with their turbo set-ups"
This might be true, but they have full race motors that also don't have water jackets and are not intended for street use most if not all of the time.
If we're talking basic turbo kits like Drag, F-Max, etc. then my original statements hold true - the VTEC motor will outpower the non-VTEC.
You should preach what you know, not what you hear. Vtrec and turbo get along fine, WTF cancel each other out? Well you are at the right place, stick around here and learn. Read Read Read.
Guest
Posts: n/a
Re: rumors need to be cleared up... (EneMy X)
my friend has a b20/b18c1 built with a f- max turbo and hondat(can't remember) and he is having the problem I am speaking of.
at about 4500 rpm turbo spools and vtec engages, it redlines faster than i can blink at about 9500 rpm and he goes nowhere in first gear and second gear and sometimes third. he has to set the vtec engagement at 8500 rpm to move off the line...
Well then, either he or whoever is tunning that hondata doesnt know what there doing now do they? I guess when I drove my 270 WHP(stock motor, just a head gaskette) turbo h22a prelude around for 2 years I was just on acid and it really didnt work.
Good Tunning, good Tunning and some more good tunning, damn even some semi good tunning will make power.
Re: rumors need to be cleared up... (GetawayinMoscow)
New User
Bottom line:
tek_civic
08-21-2003 05:19 AM
