Frustrated as hell...........Please help
Lover
I have search this site over and over and can not find S#!T, i'm putting a 88-91 (B16A Sir 1) into a 6th gen civic, what do i need and what problems am I going to run into......please help..........any help is appreciated!!
Re: Frustrated as hell...........Please help (AK1200)
Lots of problems and you need lots of stuff.
namely a hydro tranny. a few brackets, a wire harness, throttle cable
and many other variables depending on what version of OBD you need to run.
To convert the motor to OBD 2 you will need a new distributor, alternator, oil pump and CFK sensor, knock sensor and maybe a few other things.
You are MUCH better off getting a 1996 or better B16 from a del sol or civic SI.
[Modified by tonyxcom, 10:40 PM 10/10/2002]
grab you a back issue of SCC...they have a full article about how to put it in step by step. My only ? is why the hell would you put that old *** motor into your brand new car??? I dont know how that obd2 to obd0 will work out, but more power to ya
Lover
Re: Frustrated as hell...........Please help (tonyxcom)
thanks to all........maybe the extra money for a sir2 is worth it.....thanks again
Re: Frustrated as hell...........Please help (Ricey McRicerton)
STOP!!!!!
DON'T DO IT, SAVE YOURSELF
Go with the 2nd gen B16, this will save you a huge headache and hours of down time.
Lover
Re: Frustrated as hell...........Please help (2CAMSAAM)
I take it all the sensors are the same excluding VTEC obvisously. just replace the ecu and maybe a VTEC controller?
Lover
Ok so I go with the b16 sir2, what axles can I use? the ECU can be chipped with HONDATA correct?
94-del slo gsr
26
09-26-2016 10:21 PM
hitmancivic
06-09-2007 07:13 PM
