HELP:Rear disc conversion
hey, recent l bought a GSR rear disc conversion for my EG HB. When I picked it up, it did not come with the e-brake cable. So what I am wondering is if a 90-93 Teg -ebrake cable will work on the DC conversion. If you have any suggestion, please help. If you are not going to HELP, please keep your comments to yourself- that would greatly be appreciated.
TIA
TIA
Re: HELP:Rear disc conversion (skunk2unerz)
Not sure if its right, but i've heard you will want an EX e-brake cable. I'm currently looking into this stuff myself, checking on a possible del sol rear brake deal.
Re: HELP:Rear disc conversion (bikeboy80)
you can use any 3rd gen integra cables, not sure about 2nd gen though
As long as it's the 2 door not the 4 door. I'm using the 4 door brake cables on my 93 H/B and its a tad bit too long, nevertheless it works!
Re: HELP:Rear disc conversion (Aka-Willi)
Okay, my ebrake cable is from a 92( ithink) LS Teg 2DR. I already ran the lines to the parking brake and the rear disc. It just seems like its just too long. Any suggestions?
Thanks for you replies.......
[Modified by skunk2unerz, 9:20 PM 10/8/2002]
Uhh, not sure about the 2nd Gen Integra brake cables working man. You don't want your car rollin' away from you parked on a hill, since it is too long. Best get the 3rd gen brake cables.
New User
The EG Civic EX or SI cables will work as well. You should be able to get those from just about any junk yard.
Mike
Mike
Re: HELP:Rear disc conversion (splitime)
Get some 3G 2-door Teg cables
Re: HELP:Rear disc conversion (CivicNewbie)
same q's but more added,
What is nescesary for the conversion? I have a del so I have been parting out and i am removing the final parts for my car. Do I need the entire arm or just the spindles and calipers??
Madhatch on FP's CPU
The EG EX doesn't come with rear disc brake, I wonder how you would use the drum e-brake cables for rear disc setup?
Umm, yes they do. (Well, some of them anyway) The rear disc swap for my 95 EX coupe came from a 92 EX sedan. (That cable'll work too )
From 1994 up, 4 wheel disc brakes were avaible on cars equiped with optional ABS
wesuri
09-07-2005 01:14 AM
superR303
10-05-2001 09:58 PM
