Timing belt question??? need help
Id like to know if theres a Balance Belt on the SOHC civic...its a 96 ex...
Is hard to replace a timing belt??? Is there anything that i should remember like tips to make it easier...appreciate the feedback
Solbros Owns Me
Re: Timing belt question??? need help (smkngsr)
Balance Belt?? Never heard of it.
It's really straight forward. Few tips which are pretty obvious..
1. Remove plugs-easier to rotate engine when finding TDC etc
2. replace water pump at same time-why not?
3. Torque tensioner to spec
Get a Helms/Haynes/Chiltons and you'll be fine. It's really straight forward. Just got to remove accessory belts, get engine to TDC and remove/replace. Instructions are easy to follow as well. Oh, get an OEM belt
Re: Timing belt question??? need help (Emerica)
Thanks bro...coz i did an accord before and theres a balance belt to smoothen the engine otherwise it will shake...and thats connected to oil pump...since u told me that theres no balance belt then, it should be easy then...thanks a million bro
no civic has the balance shaft belt, and no its not hard to replace refere to a shop manual torque everthing to honda specs, dont want anything too loose, or too tight and could strip out bolts, don't attempt if you feel uncomfortable, one timing mark and then you will be in a world of ****.
