Back tire wobble...?? help please
Old 12-21-2002, 08:32 AM
97DX's Avatar
Default Back tire wobble...?? help please
my back tire, i believe on the driverside, is wobbling when i drive. what in the hell could be wrong?
Old 12-21-2002, 08:33 AM
degooser's Avatar
Default Re: Back tire wobble...?? help please (97DX)
Bent rim...
stay away from potholes....
missing lug nuts...
maybe only ones holding your rim on...
Old 12-21-2002, 08:36 AM
JasonBlackEJ1's Avatar
try tightening ur lug nuts. and like the other guy said, a bent rim.
Old 12-21-2002, 11:06 AM
SpiritUnreal's Avatar
Default Re: Back tire wobble...?? help please (FLAMENCOVTEC)
It could just be the tire too, go get the tire changed and if it doesn't clear up its prolly the rim.
My back tire and front drivers side tires wre doing that, turns out the tires were just bad. Didn't realize that until the tire blew up and whacked away at my fenders, and jacked it all up...friggin sheet metal
Old 12-23-2002, 11:12 AM
97DX's Avatar
Default Re: Back tire wobble...?? help please (SpiritUnreal)
thanks for the info guys..thats what i thought. well..its still under warranty so back to the dealer i go....this is the second time they have "fixed" this problem
Old 12-23-2002, 12:27 PM
t0p_sh0tta's Avatar
how many miles are on the car?
Old 12-23-2002, 01:03 PM
euclid's Avatar
Default Re: Back tire wobble...?? help please (t0p_sh0tta)
everyone seems to have missed the obvious here, i bet your wheel weight just fell off. that will definately make it wobble. you can get it fixed for about $1.
Old 12-23-2002, 01:17 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Back tire wobble...?? help please (euclid)
I worked in a tire shop for a year and a half and the most common ailment was wobbling tires. Solution? Get your wheels and tires balanced. I doubt it's a bent rim because that usually makes your car pull to one side...if it's not pulling you probably just shed a weight. Then again, you could have bent a strut, bent a lug stud, badly warped a rotor (you would have many other problems if it were that), etc. Get it balanced at SAM's for like 8 bucks and if the problem persists, get back to us.
Old 12-23-2002, 02:08 PM
Bondel Slo's Avatar
Default Re: Back tire wobble...?? help please (Archidictus)
Wheel bearing is another option not to rule out...
Old 12-23-2002, 04:24 PM
EK MONEY's Avatar
Default Re: Back tire wobble...?? help please (Bondel Slo)
hub, tire, wheel weight, lugs
Old 12-26-2002, 06:59 AM
97DX's Avatar
Default Re: Back tire wobble...?? help please (Peagreenhatch)
ya the whole car kinda seems to wobble, the steering wheel is doin it too. so im not sure if its the back or front.
Old 12-26-2002, 07:05 AM
JaeOne3345's Avatar
have u looked at the TRAILING ARM BUSHING??
i bet its ripped/broken. happens a lot of on older EF's, shouldnt be happening on a ek so soon tho but who knows.
Old 12-30-2002, 05:18 PM
97DX's Avatar
Default Re: Back tire wobble...?? help please (JaeOne3345)
FIXED...damn tire was seperating...40bucks..new tire...all good, thanks for the suggestions tho guys...
cherrynutz
Honda Civic (2001 - 2005)
07-03-2007 02:45 PM
erikiksaz1
09-02-2006 01:52 PM
erikiksaz1
04-05-2004 10:15 PM
integranator
01-01-2003 08:14 AM
TypeR1558
08-06-2001 07:21 AM
Quick Reply: Back tire wobble...?? help please
