00 Si, parts compatibility (bumpers, lights, suspension)
I might be purchasing a nearly bare shell from a 2000 Si. It needs bumpers, lights and suspension among other things. I was just wondering what years bumpers, tail lights and headlights might fit: any year from 96-00, or must they be from a particular year? Also, can these parts come from a sedan or hatch, or only from a coupe?
Concerning the suspension and brakes, basically the same question: can I fit parts from other generations of Civics (knuckles, calipers, wishbones, etc.) or must I buy 96-00 stuff, or specifically Si stuff? I need the brakes to be at least as big as stock as this will be a rae car. Thanks.
Re: 00 Si, parts compatibility (Civic44)
I can't believe your asking this ?
You'll need 99-00 any civic headlamps, taillamps (coupe), front bumper (any). rear bumper (coupe), side skirts (coupe/hatch - painted to match)
99-00 si onlylip spoiler, front grill, f & r sway bar, front Lca's & front forks, shocks & springs (or use aftermkt)
(96-00EX or 99-00Si) hubs/spindles/ brakes front & rear....not sure if you still have the Si master cylinder, prop valve, ebrake lines, etc (i believe the brake booster is the same )
other suspension pieces can be used from any 96-00 civic (i believe - feel free to correct me if I am wrong)
Re: 00 Si, parts compatibility (ProEater)
Thank you for the responses so far.
Shocks and springs will be koni-ground control
Swaybars will be aftermarket.
Is there any way to fit any part of my 90-93 integra brake system (10.2 inch)? Are the Si brakes bigger than the Integra brakes?
Does the grill from other coupes not fit? I don't care if it looks like an Si or not, I just want to make a complete-looking car.
Thanks.
Thanks.
brakes are the same rotor size 10.3" in the front so they should work but may not have the same fittings - check HERE ---> https://honda-tech.com/zerothread?id=152884 ---after searching I would say look for 96-00 ex brake swap for easier installation
any 99-00 civic grill will work...you can have my dx one (painted tafetta white) in the next couple of weeks I am getting the si grill painted to match my car
Snail Power
01-30-2009 03:37 AM
Navid OG
10-14-2003 10:14 AM
