Will 99 Si knuckles fix the camber problem for my Gsr front disc brake conversion?
I will be swapping out my front brakes from my 98 Civic HB for some 99 Integra front brakes. I have read alot about camber problems using Gsr front brakes. Could I use the Gsr rotors and calipers, but use 99-00 Civic Si knuckles? Will this fix the camber problem? And are Gsr rear trailing arms exactly like the civic's?
thanks.
thanks.
Re: Will 99 Si knuckles fix the camber problem for my Gsr front disc brake conversion? (PYITR821)
You shouldnt have any problems at all changing the front brakes out, I had Integra brakes all the way around on my 99' hatch and there were no problems. The only way you will have a camber problem is if the car is lowered, then you will need some adjustable upper control arms to fix that. Otherwise you will be good to go changing out the brakes.
Re: Will 99 Si knuckles fix the camber problem for my Gsr front disc brake conversion? (H22EK9)
you sure? Everyone says the Gsr knuckles are taller than the civic giving you positive camber.
Marvin1985
Suspension & Brakes
03-18-2014 08:36 PM
UrbanEh
02-01-2007 03:35 AM
Kool305
02-01-2004 11:40 AM
