please dont fail me now HondaTech
yes ive searched but have not found anything useful in the four pages of overheating questions. Here is what I have done to my stock JDM B16 hatch to try and fix it:
New OEM Honda thermostat
fan stays on constantly because i put the two wires together
Resurfaced head with new oem head gasket
new auto zone del sol dual core radiator that I got for free
new radiator cap
I bypassed the heater core due to leaks around that area
ground wires are secure
pump is good
if it matters im running an LS dizzy
i bled the system correctly
heres the problem:
it only overheats when im on the freeway cruising in fifth gear at about four thousand RPMs. To let the temp get down when it overheats I put it in nuetral and let it roll, then I put it back in gear and as soon as I do that the temp goes back down to a little above normal. When I pull over to open the radiator cap it is mostly air that comes out with the fluid gushing out. please help me honda tech, im just getting tired of this damn overheating and I do not want to warp the head again because I just finished putting it back on. TIA!
new radiator cap
pump is good
heres the problem:
Re: please dont fail me now HondaTech (EG6 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR »</TD></TR><TR><TD CLASS="quote"> When I pull over to open the radiator cap it is mostly air that comes out with the fluid gushing out. </TD></TR></TABLE>
How much fluid are you putting in? How exactly are you bleeding the system?
To bleed the system I always fill the radiator, start the car and let it run till the cooling fan comes on, while always adding fluid. Doing this will help the air bubles traped in the system to be pushed to the top.
If you loosing fluid, where is it going? It either has to got out or in. Have you looked for water marks on the motor? Could be hitting the exhaust and evaporate before hittinig the ground. OR its going inside the motor. Check the oil. Does it look like chochlate (SP?) milk
Unceasing Measure
You're either leaking or burning coolant. Does your heat work? Does the inside of your car smell sweet? It's possible that your heater core is going bad (gone bad) and needs replacement. Also, check your incoming heater hoses at the firewall, the IACV lines, etc.
EDIT: just reread your list. Obviously it's not the heater core. Um, blowing any white smoke?
Sometimes it's the simplest thing that gets over-looked. Does your temp guage work properly? Maybe your car isn't over-heating. Maybe the guage is just bad, or your temp. sensor. If you can, hook up an aftermarket guage with actual degrees to see where you are at highway speeds. does the car over-heat if you flog it around town? Or just on the highway? I had a motor that would overheat on the highway, until I turned the heater on. I replaced the motor(it was a 92 cx).
Down Since Day 1
Re: please dont fail me now HondaTech (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">headgasket!!!
sorry.....</TD></TR></TABLE>
Easiest way to check is for leaks or oily coolant in the radiator. But I would say that the gasket is bad.
Re: (Jmunk)
Since you said that mostly air comes out them obviously the coolant is going somewhere. Check for leaks and check your motor oil and see if it looks funny. You can also smell it, if it has coolant in it it will have a funky smell. If no leaks them there is probably a sealing issue. Check where the head and block meet all around the engine for any white marks. Why did the head get resurfaced? The head couldve not been resurfaced right, the headgasket is bad, or the deck of the block is not level and not sealing right with the head.
Re: please dont fail me now HondaTech (b18cx)
no chocolate oil.
im positive its not the head gasket because i just did a head gasket about two days ago and trust me I know how to do it properly.
im not leaking any fluid.
i bypassed the heater core because the actually heater core was leaking so there is no fluid going to the heater core right now.
the only thing i could think of is maybe the sending unit for the gauge.
sorry, im just frustrated and im running out of ideas. so more info would be appreciated. maybe something i overlooked. TIA
Down Since Day 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR »</TD></TR><TR><TD CLASS="quote">no chocolate oil.
Not saying you dont know how to do it, just that parts can be defective.
Re: please dont fail me now HondaTech (CXinthemaking)
who replaced your headgasket? Could be on upside down. It looks like you had this problem before you replaced the headgasket though, so I guess forget that.
I had the same problem as you, and it ended up being the coolant thermo switch, but your fans are always on, so thats obviously not it.
Bump for help.
Bump for help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR »</TD></TR><TR><TD CLASS="quote">.......... tired of this damn overheating and I do not want to warp the head again because I just finished putting it back on. TIA! </TD></TR></TABLE>
Maybe the block needs to be decked. Damage was not only to the head the first time, it also warped the deck of the block.
Re: (5w20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5w20 »</TD></TR><TR><TD CLASS="quote">Since you said that mostly air comes out them obviously the coolant is going somewhere. Check for leaks and check your motor oil and see if it looks funny. You can also smell it, if it has coolant in it it will have a funky smell. If no leaks them there is probably a sealing issue. Check where the head and block meet all around the engine for any white marks. Why did the head get resurfaced? The head couldve not been resurfaced right, the headgasket is bad, or the deck of the block is not level and not sealing right with the head.</TD></TR></TABLE>
check the ect sensor, radiator cap with the proper spec., and do the compression test on the coolant system to see if you have any leaks. just a thought head gasket upside down?
crackhead. i mean you probably got a cracked head. check for combustion gases in you coolant. that test can also test for bad head gasket. i forgot what the test is called. but you stick something into filler neck of you radiator and it mixes some type of fluid with your coolant and when if it changes color then you have some type of combustion gas.
maybe your coolant to water ratio is wrong. to much/little coolant can make a car do some crazy things
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicmatt »</TD></TR><TR><TD CLASS="quote">Sometimes it's the simplest thing that gets over-looked. Does your temp guage work properly? Maybe your car isn't over-heating. Maybe the guage is just bad, or your temp. sensor. If you can, hook up an aftermarket guage with actual degrees to see where you are at highway speeds. does the car over-heat if you flog it around town? Or just on the highway? I had a motor that would overheat on the highway, until I turned the heater on. I replaced the motor(it was a 92 cx).</TD></TR></TABLE>
this guy also make a good point...sometimes we get soo far ahead of our selfs we over look other things
Re: please dont fail me now HondaTech (Who Said)
the reason the head was resurfaced was because I always resurface the head when I change a head gasket. At least that is what I was taught. There are no leaks in the system at all. I dont blow white smoke. And there is no oil in the coolant (that was the whole reason I changed the headgasket, because of oil in the coolant=blown head gasket).
I bled the coolant system again and took it for a drive and it over heated again. I pulled over and took the radiator cap off slowly and didnt notice any air gushing out. The coolant was actually level. So I took it for a drive again and it overheated again and I turned on my lights because it was getting dark and all of a sudden the temp. jumped down a little, I guess this means I have a bad ground or something, right? What should I check if it is an electrical problem? Should I buy new engine ground wires? This motor did not overheat in the car it was in before. The SOHC motor I had before did the same thing that this DOHC is doing now, so now my last shot would have to be with something electrical. Anything would help H-T! TIA!
Solbros Owns Me
I'm going with headgasket also.
I've had problems with sealing before also...and I've done more head gaskets than years I have lived
Re: please dont fail me now HondaTech (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">I'm going with headgasket also.
I've had problems with sealing before also...and I've done more head gaskets than years I have lived </TD></TR></TABLE>
yes, but would the exact same problem happen with two different motors. Like I said before, the motor I have now did not overheat at all in my friends car. Is there any electrical connections I should check. TIA
I would check the engine ground wires. I had some of the same problems and it turned out that the engine ground near the trans was corroding. My Other ground (near the valve cover) was not installed after the swap. Once the ground wire was cleaned up my problems were gone.
