GSR connector on LS distributor.... help me out please!! :)
LS connection: two connectors, 9 wires
GSR connection: one connector, 9 wires
all of the wire colors are the same, so i'm hoping i can just cut off the two connectors on the LS dist, and wire in the one connector from the GSR dist, but i just want to verify that this will work before i start cutting, and splicing! the connector on the wiring harness in my engine bay will only accpet the GSR style connector, not the ls one, which is why i need the GSR connector on the ls dist!
Car: 98 civic HX
motor: 93 ls head 97 ls block
ECU: obd2>obd1 adapter, obd1 LS ECU
any help is greatly appreciated!
Car: 98 civic HX
It will work. Cut the plug off of the OBD 1 unit and color match them to the OBD 2 unit. You could also go to radio shack and buy new pins and just repin it other than cutting and splicing, but whatever is easier for you.
LS=OBD1
GSR=OBD2
Hope this helps
LS=OBD1
GSR=OBD2
Hope this helps
Re: GSR connector on LS distributor.... help me out please!! :) (speedfreek128)
If you havent figured it out yet trevor, call me up... its quite easy... we just did it on jennis car...
Re: GSR connector on LS distributor.... help me out please!! :) (crxaccord)
yea, i know which dist is which, i just wanted to make sure it worked before i started cutting wires and ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxaccord »</TD></TR><TR><TD CLASS="quote">If you havent figured it out yet trevor, call me up... its quite easy... we just did it on jennis car...
thanks ameen! did you get her car up and running?
Re: GSR connector on LS distributor.... help me out please!! :) (THE_HX)
yea we got it "running"... just need to adjust the throttle cable, belts, etc and it will be on the road today...
