Must be absolutely positive - 92-95 Civic seat rails in 94-01 Integra
I said I don't want a title!
Please do not answer if you do not know for sure.
I need to know if the 92-95 Civic seat brackets/rails are the exact same bolt pattern as the 94-01 Integra rails. Baically, could I unbolt a pair of seats from a teg and bolt them directly to the mounting locations on a 92-95 Civic?
I'm ordering aftermarket brackets and they have a set of 92-95 Civic in stock but nothing for a 94-01 teg. My argument is that, thought different part numbers, the brackets should be the same.
Thanks.
Thanks.
Re: Must be absolutely positive - 92-95 Civic seat rails in 94-01 Integra (Todd00)
GSR seats going into a 92-95 civc. dont know if it helps.
https://honda-tech.com/zerothread?id=850856
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">Please do not answer if you do not know for sure.
I need to know if the 92-95 Civic seat rails are the exact same bolt pattern as the 94-01 Integra rails. Baically, could I unbolt a pair of seats from a teg and bolt them directly to the mounting locations on a 92-95 Civic?
Thanks.</TD></TR></TABLE>
Nope, my buddy has gsr leathers in his 92-95 hatch. Only 3 bolts bolt down. He thinks this is sufficient enough. I guess it all depends on how you feel about it.
brakets are the same, although some people say that moving a teg seat in an 92-95 civic gives you a higher seat posistion. and puting civic seats into a teg would net you a lower seat posistion. i didn't notice any difference when i put my seats in my car.
the mounting holes are the EXACT same. i unbolted my seats out of an ITR and bolted them into my car
Re: Must be absolutely positive - 92-95 Civic seat rails in 94-01 Integra (slammed_93_hatch)
same exact here aswell.. i have integra ls seats in my civic and they bolt up perfectly..
Re: Must be absolutely positive - 92-95 Civic seat rails in 94-01 Integra (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">Nope, my buddy has gsr leathers in his 92-95 hatch. Only 3 bolts bolt down. He thinks this is sufficient enough. I guess it all depends on how you feel about it.</TD></TR></TABLE>
He has 94-01 seats in his 92-95 and they don't bolt in? He needs to loosen all the bolts and try again. All 4 should work fine. Mine do. All of the bolts are critical from an accident-survival point of view.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">brakets are the same,
the mounting holes are the EXACT same. i unbolted my seats out of an ITR and bolted them into my car</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 »</TD></TR><TR><TD CLASS="quote">same exact here aswell.. i have integra ls seats in my civic and they bolt up perfectly..</TD></TR></TABLE>
Yippers
Yippers
Ok, cool. So you guys basically lifted the seats straight out of a teg, rails/sliders and all and put them directly into your 92-95 hatches?
If this is the case, then I don't see why the 92-95 Civic aftermarket seat rails won't bolt directly into my Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">Ok, cool. So you guys basically lifted the seats straight out of a teg, rails/sliders and all and put them directly into your 92-95 hatches?
If this is the case, then I don't see why the 92-95 Civic aftermarket seat rails won't bolt directly into my Integra.</TD></TR></TABLE>
i think this will help you even more.
my friend bought GSR seat but they didn't have the slider/rails. so he took the ones off of his 92-95 civic seats and bolted them up too the GSR's and it worked perfect
YES. 92-95 civics same bolt pattern with 94-01 Tegs. im using GSR seats in my 92 civic
however with the 96 and up civics only 3 bolts with line up
my friend bought GSR seat but they didn't have the slider/rails. so he took the ones off of his 92-95 civic seats and bolted them up too the GSR's and it worked perfect</TD></TR></TABLE>
Well, no. I'm installing Sparco Seats into my teg and Sparco has a new seat bracket kit out for them, but they only have the 92-95 Civic bracket/rail in stock (not sliders, I don't care about sliders). This is why I needed to know for sure if the 92-95 floorpan bolt pattern was indeed the same as the 94-01 teg floorpan bolt pattern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">Well, no. I'm installing Sparco Seats into my teg and Sparco has a new seat rail kit out for them, but they only have the 92-95 Civic rail in stock. This is why I needed to know for sure if the 92-95 floorpan bolt pattern was indeed the same as the 94-01 teg floorpan bolt pattern.</TD></TR></TABLE>
Should work fine. You mean the bracket, right? The rails are universal, it's the seat bracket that is model-specific. Don't see why it wouldn't work, I have one sitting in my room that I just looked at.
Maybe your friend got a set of 90-93 leather seats, and they won't bolt in correctly. New Integra seats should match all 4 holes.
How can I make the integra seats fit into a 99 civic coupe. Only 3 bolts line up.
Re: Must be absolutely positive - 92-95 Civic seat rails in 94-01 Integra (99FBPSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi »</TD></TR><TR><TD CLASS="quote">How can I make the integra seats fit into a 99 civic coupe. Only 3 bolts line up.</TD></TR></TABLE>
use the stock rail from the civic seats, it will bolt straight in the teg seats
It's weird, I picked up Recaro passenger seat, and a friend gave me an OEM Honda ITR bracket/slider, and 3 holes matched up perfectly, but the fourth, (rear left) is off by about 2inches. These fit perfectly inside an ITR, but not in my 93 hatch. I've never run into this problem with friends cars, and I've helped swap interior (Integra into Civic) at least a dozen times over the years. Very strange.
coot_er
17
12-31-2005 09:26 AM
