Replaced timing belt...now car screeches?
I have just replaced my timing belt...and now my car screeches...i found out that the timing belt was "coming off" of the pulleys and rubbing against the plastic cover. What could be wrong?
Re: Replaced timing belt...now car screeches? (Eee Pee)
you forgot the outter belt spacer/guide,go and pull the power steerin belt of alt belt and ac(if with)belt and pull the crank pulley off and see if the belt guide is butted up against the belt and around the crank shaft after the pulley,if not then put it back on...make shure there is one on the other side to closest to the oil pump housing also
Re: Replaced timing belt...now car screeches? (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling »</TD></TR><TR><TD CLASS="quote">accessory belts are loose. tighten them</TD></TR></TABLE>
ttt anything else i should look for? what about a bad tensioner?
Re: Replaced timing belt...now car screeches? (trooper0641)
Your bottom guide for the crank gear is off and that causes the belt to "walk" off. As for the screeching loosen the belt and re tighten t it is probably too tight.
screeching is almost always a loose belt, i know form experience
EDIT- probably the alt. belt, does it screech right when you turn your car on and/or when you turn your lights on? all you have to do is tighten a bolt on the alternator (14mm?)
Re: Replaced timing belt...now car screeches? (CXinthemaking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXinthemaking »</TD></TR><TR><TD CLASS="quote">
EDIT- probably the alt. belt, does it screech right when you turn your car on and/or when you turn your lights on? all you have to do is tighten a bolt on the alternator (14mm?) </TD></TR></TABLE>
yes you are so right!
age_texas
06-04-2012 07:20 AM
