D15b7 Oil Pan Compatible With A D16z6 Block?
Thats the real simple question guys I found one post by searching that said all D series pans are the same except the Y8 one which is aluminum. My z6 pan is shot and I have someone offering to sell me a d15b7 pan I just want to make sure it will bolt right up? Thanks in advance guys
Re: (DelSolSi93)
I had one and it bolted up but my oil pick up was so close to the bottom that it wouldn't work. I'm pretty sure it was a b7 pan but it was alot shallower then my z6 pan.
Re: (djfob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">actually, i dont know if they will, i tried installing a d15 (89 dx) one on my z6 and it wasnt going to happen, so i dont know if it will work properly....</TD></TR></TABLE>
you also said it was from an 89 dx, the 92+ engines are different so that was your problem
Re: (djfob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djfob »</TD></TR><TR><TD CLASS="quote">I had one and it bolted up but my oil pick up was so close to the bottom that it wouldn't work. I'm pretty sure it was a b7 pan but it was alot shallower then my z6 pan.</TD></TR></TABLE>
Does anyone else know if this is true?
Re: (Apocolipse269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocolipse269 »</TD></TR><TR><TD CLASS="quote">
you also said it was from an 89 dx, the 92+ engines are different so that was your problem</TD></TR></TABLE>
the NON vtec oil pans for 88-95 are the same, at least thats what the autopart stores say, so i doubt that was the issue, i might even measure them if i get bored enough i have about 6 blown sohc's..i just need some time...
Re: D15b7 Oil Pan Compatible With A D16z6 Block? (DelSolSi93)
Nerologic, you have 6 full SOHC engines? wut make? d16z6? would you sell me the head, the head gasket, timimg belt, and oil pressure wire & plug for a mini-me swap?
Re: D15b7 Oil Pan Compatible With A D16z6 Block? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSi93 »</TD></TR><TR><TD CLASS="quote">PM'd with payment questions </TD></TR></TABLE>
Il to to UPS in person tomarow and let you know...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apocolipse269 »</TD></TR><TR><TD CLASS="quote">Nerologic, you have 6 full SOHC engines? wut make? d16z6? would you sell me the head, the head gasket, timimg belt, and oil pressure wire & plug for a mini-me swap?</TD></TR></TABLE>
obd1 or obd0?? 5 of them are z6's Pm me for more info, but yeah i can hook ya up man...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">D15B7 and D16Z6 oil pans are the same ... 11200-P08-020
89 DX is different part # 11200-PM3-020 </TD></TR></TABLE>
figures. i got teh part numbers from the local "autozone"
Re: D15b7 Oil Pan Compatible With A D16z6 Block? (Nerologic)
figures. i got teh part numbers from the local "autozone"</TD></TR></TABLE>
Autozone sucks, PMd back with further info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSi93 »</TD></TR><TR><TD CLASS="quote">Thumbs Up to Nerologic for an awesome sale and ultra fast shipping! </TD></TR></TABLE>
no worries man, i hope u fixed everything out with that shop....
no worries man, i hope u fixed everything out with that shop....</TD></TR></TABLE>
Yeah everything worked out, I just took it back and had them take it all apart and do it all over and re-seal everything with twice as much hondabond and fill it correctly and its fine now, thanks again for helping me out, its so nice to be able to drive my car again.
mike93eh2
10-04-2006 07:29 PM
JforJonathan
04-08-2005 08:48 AM
