LS SWAP INTO EK NEED HELP!
Location: Seattle/Ligonier, WA/PA, United States of Honda
Ok well i have gotten pretty much all the parts i have a 94 ls motor and i know i need to 99 civic si drivers side mount, the problem is i was looking at my buddies si with an obd2 ls engine and the mount that comes off the block is much wider and the studs that come of the mount are a lot shorter the mount that comes off the block i have has 2 really long studs and they are close together which makes the si mount not fit on the them. my question is do i have to buy the mount off the block from an obd2 ls motor or could i take the studs out of the mount on the block and put my dseries ones in and then widen the holes on the mount that comes off the bracket? need help asap i have already searched and cant find ****.
Re: LS SWAP INTO EK NEED HELP! (SpoolinEK9)
i did the same swap in my car...what you need is mostly 99-00 Civic Si pasrts
AC bracket
front tranny mount
rear motor mount
Si axles
AC bracket
front tranny mount
rear motor mount
Si axles
Re: LS SWAP INTO EK NEED HELP! (JDMFreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">i did the same swap in my car...what you need is mostly 99-00 Civic Si pasrts
AC bracket
front tranny mount
rear motor mount
Si axles</TD></TR></TABLE>
Your list is not quite right.
The things you need from the si are:
-the rear tranny bracket(keep your stock rubber mount)
-the bracket on the driverside, that runs between the mount bolted to the block and your stock fluid filled mount on the chassis.
*any '94-up B series axles will work. They dont need to be from the si.
AC bracket
front tranny mount
rear motor mount
Re: LS SWAP INTO EK NEED HELP! (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">
*any '94-up B series axles will work. They dont need to be from the si. </TD></TR></TABLE>
I used the left side engine mount bracket off of the 00 si ,
but I am putting a 94 LS motor with an automatic tranny
I don't know what rear mount or mount bracket
to use for this swap I am not sure if the si will
fit being it is 5 speed and I am using an automatic.
any answers.
Modified by leckey73 at 8:36 PM 9/6/2004
any answers.
ChinitodeNJ
11
08-10-2009 01:45 PM
ProjectBoosted
Northwest (Sales)
01-22-2008 07:05 PM
