Drive master cylinder brace on an EK ~~ pic ~~
Has anyone installed a Drive master cylinder brace on an EK yet? I heard that 1 hole must be drilled in order to install it onto a 96-00 Civic, is this true? Can anyone confirm this?
Post pics if you have one installed.
Re: Drive master cylinder brace on an EK ~~ pic ~~ (Draggin99Si)
Even if one hole needs to be drilled, it still wouldn't be threaded to screw a bolt in.
A search yielded no info on an EK install, so evening bump!!
If i remmber correctly, the location where that hole that needs to be drilled should be enough thickness where you could tap it to proper thread ..
1 Post
wtf is this thing supposed to do? just brace the master clutch cylinder? Ive never seemed to have a problem with mine moving on me.
Re: Drive master cylinder brace on an EK ~~ pic ~~ (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">wtf is this thing supposed to do? just brace the master clutch cylinder? Ive never seemed to have a problem with mine moving on me.</TD></TR></TABLE>
thats because you never had to press down on your brakes hard enough to need it.
there was some serious debate a while back on those.
The side that swayed me to stay away from them was that the brake pedal brace can/will actually change the suspension settings with it if you push really hard on the brake going into a corner.
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">wtf is this thing supposed to do? just brace the master clutch cylinder? </TD></TR></TABLE>
Yes, that sure does sound like what a master cylinder brace might do.
But under intense braking/racing conditions the master cylinder moves around. If you know how to bleed your own brakes watch the MC next time someone is pumping the brake pedel. You'll understand then.
I used to have it, and yes, you do have to ( sold it for this reason) drill holes, the kit comes with two bolts and nuts so that you can mount it up
KimChiKid
10
01-15-2007 11:22 AM
