Change Oil pump ?
Change Oil pump ?
So i have an LS-Vtec motor b18b block b16a head.
I'm switching out the b18b non-vtec water pump for the GSR pump. I also got the water pump gasket and GSR timing belt so i should be all set there.
I'm thinking about upgrading the oil pump while i'm in there. Are the GSR/ITR/B16 vtec oil pumps all the same? which one should i use and what extra parts do i need i.e. gaskets and such?
Part numbers would be grrrreat. Thanks guys
All Vtec Pumps are the same. here's a link for the part. It should come with the Front main seal just use some hondabond and you'll be ok.
http://www.hondaautomotiveparts.com/home.htm
Corksil
01-25-2011 10:36 AM
