is the b16a a direct swap for a 96 EX?
Re: is the b16a a direct swap for a 96 EX? (da_rimrocka)
need tranny mount,motor mounts,shift linkage. theres some other basic swap things you need but im tired so im going to bed now
I used driver side, rear, tranny si 99-00 mount, harness ffrom ex motor will work. fine for obd1 and 2. if obd1 get a boomslang conversion harness., use the b16 shift linkage, axles. Thats it i believe,
Curtis
Curtis
Re: (da_rimrocka)
sure but while your at it why dont you just replace the whole harness for $50 just make sure you solder and shield the wires when u do it(wires suck if they touch).speaking from experiance and the fact that i fried 3 harness because i chose to use electrical tape
Re: (da_rimrocka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_rimrocka »</TD></TR><TR><TD CLASS="quote">cant i just modify my current linkage and make it work??</TD></TR></TABLE>
that is what I wanted to know. They use the same diagram for the parts, but I know the part numbers are different.
Anybody know what needs to be changed or the differences? Or is it not worth the time to modify it?
Re: (darkcvc)
Guess I should have searched first, but here is some info that I have found.
https://honda-tech.com/zerothread?id=948113
http://www.performanceforum.co....html
Re: (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_rimrocka »</TD></TR><TR><TD CLASS="quote">that still doesnt answer my question tho..can the stock linkage be modified to work with the b16?</TD></TR></TABLE>
no way u can use the d series linkage...........will not work at all........
joesteppy
14
02-16-2010 02:49 AM
v8 integra
14
04-17-2006 05:49 PM
EK9Greg
12
10-08-2004 10:34 AM
