del Sol Mounts
del Sol Mounts
Whats up i Got a 2ng gen B16 in a del sol and I was wondering if the DC bodystyle Integra motor mounts will work for me and if so from 95 to wat year???
Re: del Sol Mounts (delSolSiR626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolSiR626 »</TD></TR><TR><TD CLASS="quote">Whats up i Got a 2ng gen B16 in a del sol and I was wondering if the DC bodystyle Integra motor mounts will work for me and if so from 95 to wat year???</TD></TR></TABLE>
ur stock mounts will work all u need is the rear bracket on the motor
Re: del Sol Mounts (dohcVTECeg2)
when i swapped my JDM b16 into my EG we used all stock mounts because the drivers mount from the teg was different and wouldnt work. i used all my stock d series mounts except maybe the tranny mount which came with my swap and the rear bracket
Re: (Del Sol SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol SiR »</TD></TR><TR><TD CLASS="quote">easiest thing to do is use the 94-97 Del Sol VTEC (dohc 1.6L) mounts.</TD></TR></TABLE>
thats not that easy considering he can use the mounts he has on his car now without changing a thing... the swap will come with the bracket and tranny mount if u ask for it
Re: (CRXified)
Thanks but the motor is already in its just that the driver side and the rear mounts are gone, so i was wodering what i can repalce them with and im going to get some energy suspension inserts... I dont got alot of cahs to get polyeurathanes at the moment so the temp route is stocks with inserts not the best but will have to do for now
Re: (delSolSiR626)
i used my stock mounts with no inserts, they werent torn or anything tho, they worked fine for me, no wheel hop or anything when i launched at like 4k
Re: (delSolSiR626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolSiR626 »</TD></TR><TR><TD CLASS="quote">Yeah mine lsted me about a year launching at like 5000/5500</TD></TR></TABLE>
i only launched once to do a test run, worked well and was surpised there was no wheel hop on the stock mounts
Re: (delSolSiR626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSolSiR626 »</TD></TR><TR><TD CLASS="quote">I dont got alot of cahs to get polyeurathanes at the moment so the temp route is stocks with inserts not the best but will have to do for now </TD></TR></TABLE>
stock mounts with es inserts will perform every bit as well as billet aftermarket mounts unless you are making serious power.
hotimportcrx
11-27-2005 09:32 PM
autosport7
04-29-2005 06:58 PM
ShortbusEK
05-04-2002 01:21 AM
